Question about Panasonic SC-AK75 Shelf System
I connect Panasonic CD Stereo System SA-AK 75 (110v) to a 220v power. The system is out. Is there a solution ? Thank in advance.
I conneted the Panasonic CD Stereo System SA-AK 75 to 220v. It is out of service. Is there a solution ?
zair
  • 82 Answers
SOURCE: F-61 error,dead panasonic model#sa-ak78
Have you changed the Regulator IC? Also check the IC protector next to regulator, it looks like a fusable resistor.
Posted on Dec 05, 2007
tech48
  • 624 Answers
SOURCE: panasonic sa -ak 27
This is a common error for these Panasonic units. I work at an authorized Panasonic service center and have repaired many of these.
This error is caused by either 1 of these 2 problems, both of which will require service for replacement of parts.
1. The amplifier IC is bad and needs to be replaced.
2. There are a couple of smaller components in the amp circuit that need to be replaced. One is a zener diode and the other is a resistor.
The F61 error is caused by a bad amp circuit or power supply circuit. In most cases it is the amp circuit. More often than not, it is the zener diode and resistor that are bad. This would be preferable since the amplifier IC is very expensive and a total repair cost would be close to $200. The zener diode and resistor repair would be closer to about $100 depending on the rates of the service center.
I know this may not be the answer you were hoping to get, but it is the problem you have.
If you found this information helpful in making a decision on what to do with your stereo a FixYa! rating would be appropriate and very much appreciated, after all, it is the only reward we get for offering free help to people like yourself.
If I can be of any further help just reply to the post and I will get back to you as soon as I am able.
Good luck with your stereo, I hope you found this information to be helpful.
Dave
Posted on Sep 05, 2008
dunnbiker
  • 8546 Answers
SOURCE: how to repair of panasonic cd stereo system for
Maybe a symptom would help us answer this.
Posted on Jan 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have the panasonic stereo
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 29, 2011
SD Tech
  • 14553 Answers
SOURCE: How do i fix my panasonic dvd stereo system model sa vk550 when it cannot read discs anymore and it displays "stop" everytime I insert a cd.Even a cd player cleaner.
If a no read situation either a dirty or more likely failed optical pickup in the unit.
Posted on Nov 01, 2012
How do I take a Panasonic CD stereo system model
1st check that the fan is spinning. If it is you probably need a new output IC.
Oct 20, 2014 | Audio Players & Recorders
Tip
Panasonic SA AK 67 Sterio system need spare
I have one panasonic SA AK 67 sterio system five disk changer
one plastic parts brocken inthe mechanisam area i wold like replace the mechanisam with lence what is the part number i could not find it where i can purchase new mechanisam. please help me
on Jun 30, 2008 | Panasonic SC-AK24 CD Shelf System
I have a stereo system, sa-ak 78, it wont store and change 5 cds. Think a part is broken, but cant figure which part?
The pladder may not be turning, remove top, and remove clip, now carefully pull pladder off, make a note of the position it go's back in, this will expose some of the key parts.
Mar 17, 2012 | Panasonic SC-AK600 CD Shelf System
I require a user manual for a panasonic SA AK 750 stereo system
Hi pjwivell ..
Are you sure that it SA AK 750?
well here is a here for SC AK750
download the manual and try if it works for you..
http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Mini-Systems/model.SC-AK750
please give me update if you had any success... thanks
Jun 27, 2011 | Audio Players & Recorders
Panasonic model no sa ak 67 aux not work please makenic in bokaro
my set model SA-AK67
its cd mechanism motor is not working.supply ic coming from main pcb to cd loader ocb.please advice
Apr 12, 2011 | Panasonic SC-AK24 CD Shelf System
Non Responsive Buttons
Hello..
Is this system one that has speaker connections?
If so, all the speakers must be connected for it to work right.
Apr 09, 2009 | Panasonic Electronics - Others
SA-AK91-TECHMAN
Recheck the joints of the terminals that join the boards together. Resolder the power supply.
Jan 13, 2008 | Panasonic SC-AK71 Shelf System
290 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
