Question about Frigidaire GLER341A Electric Dryer
We just bought this dryer and after drying a load I touched the top of the dryer and it was incredibly hot? is this normal?
The top of the dryer gets really really hot, and makes a squeak
    President:
  • 1,136 Answers
Hi, the squeaking noise come after it gets hot or dose it squeak right away? It sounds like the rear bearing is going bad. A very common problem with this dryer.
As far as the heat, turn the timer to heat cycle (do not start dryer tho) Open the door and see the element getting hot. If it gets hot without the motor running, the element has shorted against the cabinet.
If the element does not glow, check your 4" venting going outside and see if it is plugged with lint. If plugged, the dryer will over heat if the vent is plugged.
I hope this helps.
please let me know
Vic
Posted on May 31, 2009
  • 56 Answers
Check your vent it may be stopped up this will cause the top to get overly hot and the bearing to squeak
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
The dryer makes a loud banging and squealing noise. The top back panel on the dryer gets very hot as do the top of the dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 09, 2010 | Dryers
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Kenmore dryer hot, but doesn't dry clothes...also spueaks
Sam,
A dryer function is really simple:
Gets hot, boils left over moisture from clothes and it needs to blow it out.
If it is getting hot and it is turning - Then your problem is in the exhaust system.
Check all pipes that carry moisture/steam/vapor out of your machine and make sure is free of any restrictions.
Good Luck
Aug 18, 2009 | Roper RES7646KQ Electric Dryer
Hot Point electric dryer squeaking when in use.
It could be one of the pulleys on the bottom of the drum. Take the top and front panels off of the dryer. Get some WD-40. Now the hard part, there is no easy way, but put your right arm in underneath the drum (the right side of the drum)and spray the pulley the best you can. This is the hardest, but the easiest way to fix this problem, without having to take the entire dryer and drum apart. I had the similar problem. I didn't completely fix the problem, but the squeak has been significantly quieted.
Feb 14, 2009 | Hotpoint NWSR483EBWW Electric Dryer
Dyrer gets to hot
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
a454a
Jan 04, 2009 | Kenmore 62602 Electric Dryer
HOW DO I GET TO THE FRONT OF MY MAYTAG ELECTRIC DRYER TO FIX A PU
A lot of appliances have a spring latch under the front of the top. You need a putty knife to push this in to release the top, one on each front corner. The top will hinge up. Then a screw will be holding the front on, one on each corner of the top area. Some fronts have screws down on the lower front, you really have to look for them. Make sure the power is off!
Nov 23, 2008 | Whirlpool LER5636P Electric Dryer
Dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Nov 18, 2008 | Dryers
Squeaking kenmore dryer
Hi .thanks for the question. the noise is from the drum rollers . you can buy a drum roller kit for kenmore dryer . to repair. lift out lint screen remove 2 screws . with a flat screw driver pry the top up between the top and front at each corner. lift top 2 screws on the inside of front panel remove pull front off . remove drum . replace parts in drum repair kit . thanks the appliance doc
Oct 03, 2008 | Kenmore 63012 Electric Dryer
Dryer problem
operating thermastat or restricted vent to the outside
Apr 28, 2008 | Dryers
Frigidaire GLER341A Electric Dryer Logo
490 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
