Question about Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator
Outside door handle loose - how do I remove inside panel to tighten handle?
The handle on the front of our Fisher & Paykel fridge is loose. To tighten it I have to remove the white panel inside of the SS door. How does it remove
  • jon1651 Jun 01, 2009
    Hi Jeff
    The fridge is a SS Fisher & Paykel E522B.
    The outside handle on the upper door has no external fixing places - it sits flush with the door. The only way is to remove the white inner plastic liner and tighten probably a nut.
    Cheers Jon
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
Posted on Dec 13, 2009
    Champion:
    Habit-Forming:
  • 275 Answers
Depends on the age of the fridge, earlier E522B's had a phillips screw under the cover panels but if its a later one with square handles then the previous answers are correct.
Posted on Nov 14, 2011
    Novelist:
  • 103 Answers
Hi: I hope I'm not wasting your time. I don't recognize your brand of frige as it has symbols on it. But I've never heard of having to remove the liner to get the handle off. Check your manual or look online. I've seen High end friges that use a card to release the handle or require a nudge straight up. I'm sure you checked for small holes in the handle that require a hex wrench to release. Good luck, Jeff
Posted on May 31, 2009
    Sniper:
  • 72 Answers
You need to use 2.5 mm (metric) Allen wrench or hex key. The set screw is very tight and difficult to loosen initially. Once both of the set screws are loosened the handle will come off and you can get to the retaining screw. I added a lock washer and used Loctite thread sealer on the screw that secures the bar. Don't put Loctite on the set screw or you won't be able to remove it next time.
Posted on Jan 19, 2010
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Loose oven door handle
you must remove the inner door panel to locate the screws so that you can tighten them. hope this helps!!
Apr 06, 2014 | Fisher and Paykel OB24SDPX1 Electric...
How do i replace a fisher & paykel dw691ed ss handle
Refer this parts diagram.
http://spares.bigwarehouse.com.au/images/files/18196_71ac2010b1b67e91c23c267b28e0cae7.pdf
You have to remove the screws holding the front panel and access the door handle to replace it. Make sure the mains power chord is taken out from the plug.
Dec 14, 2013 | Fisher and Paykel Dishwashers
Broken door handle on fisher & paykel e388
look for the model number at the front, bottom of the fridge where the door meets the fridge body (eg 22021-D). Go to shop.onlineappliancespares.com.au and either buy the whole handle ($150) or just the broken lugs ($15)
Nov 17, 2012 | Refrigerators
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I have a fisher and paykel E522B refridgerator and the door handle is coming off. I need to know how the door handle is attached so I can retighten it
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Dec 13, 2009 | Fisher and Paykel E522B Stainless Steel...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Logo
2,254 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
