Question about Kenmore 53502 / 53504 Side by Side Refrigerator
Ice maker wont fill
The ice maker runs through a full cycle but does not fill with water. You are still able to get water from the door. A week ago I had to unplug the solenoid inlet valve because it wouldn't shut off and flooded the Ice maker. Does not fill since plugging it back in.
    President:
  • 1,136 Answers
Hi, It sounds like the inlet valve needs changes. Could be the plunger inside the solenoid is not lifting to allow water through. If you remove the line going to the ice maker off the inlet valve, try and cycle the ice maker and put the inlet valve over a bucket to see if water is coming out when it gets voltage.
I hope this helps.Please let me knwo if I can assist you further.
Thanks
Vic
Posted on May 31, 2009
We replaced the ice maker in our Samsung refrigerator and now we cannot get the water to dispense once we cut the water back on. What do we need to check?
By your question, you are saying you are not receiving water from the water dispenser. Make sure the electrical connector you disconnected when making the ice maker repair is securely re-seated. If you removed the door to make this repair, there is also a connector at the top of the door make sure it is also seated. The only other connection for water or ice delivery is at the water inlet at bottom rear of fridge. There are two relays at the water inlet, one for water, one for ice. If these were disturbed recheck that they were reconnected. Of course these checks should be performed with the power cord disconnected to prevent shock. Once all is checked, plug fridge back in. When dispensing water you should hear a solid clunk as the relay engages. As for the ice dispenser you will only hear the clunk as it requires water to fill the tray. Just remember to allow for two complete cycles (fill - freeze - dump) before receiving full cubes. Oh, by all means don't forget to make sure the Ice bucket full lever (Usually a thick wire) running the length of the bucket Is in the down (empty) position. If it is up, this turns off the ice maker indicating the bucket is full. New ice maker units usually come packaged with the (bailer wire) in the up (off) position.
Hope this info helps!
Dec 28, 2014 | Samsung RS2630SH Side by Side Refrigerator
Reset the ice maker back to making ice again
Turn the water supply off to the fridge, make sure the bailer wire (ice level bar) is in the down position. let the Ice maker run thru its cycle. When the cycle is complete the fingers that push out the cubes should all be down. Unplug the fridge for about 5 min. During this time turn the water supply back on. Plug the fridge back in and let it run thru a few cycles. This should reset the icemaker cycle. As a note: you should be able to hear the water turn on with a solid thump as the valve opens to fill the cube trays inside the icemaker.
Sep 18, 2014 | Samsung Refrigerators
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
Ice maker just stopped making ice. had no problem up to a complete stop
Hi and welcome to FixYa, I am Kelly
First off make sure the water in door still works. If it does not work suspect the door / light switch.
Next make sure the freezer temp is below 16 Deg F. The ice maker has a thermostat that starts the ice harvest / fill cycle and if the freezer is warming up because of automatic defrosting problems (Ice build up on the evaporator coils) the ice maker will never cycle. If you note an ice build up in the back of the freezer compartment or poor air flow from the evaporator fan you have an automatic defrosting problem. If the fan is not running at full speed the bearings or windings on the evaporator fan are failing and there is not enough air flow to get the freezer to @ or Below 16 F.
Check to make sure the evaporator fan in the freezer and the condenser fan in the rear bottom of the unit are running un-obstructed. (clean as necessary.... but if the front of the cabinet is hot to the touch then the condenser coils my be clogged with lint or... the condenser fan is not running full speed.
The ice maker may be cycling but it may not be filling with water. If it is cycling but your not getting any water.... at all the prime suspect is the solenoid on the inlet water valve. The water valve is not repairable.
Make sure that the rubber fill tube on the back of ice maker is not blocked with ice... squeeze the end of the tube. If it is frozen with ice... the inlet water valve is bypassing water off cycle and causing the tube to freeze up. The only remedy for this is to replace the inlet water valve.
Thanks for choosing FixYa,
Kelly
Apr 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My icemaker has stopped receiving water
it sounds like your water valve is bad. you have a double water valve - one side operates the ice maker and the other side operates the water dispenser. the ice maker side of the valve is bad.
you can manually pour a little water in the ice maker ice mold and wait an hour or so - if it dumps the ice then you know for sure that the ice maker is cycling and water is not getting to the ice maker from the water valved
May 25, 2010 | GE GSS20IEP Side by Side Refrigerator
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Ice maker not making ice
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 19, 2008 | KitchenAid KSRP25FN Side by Side...
Ice Maker
First, are you getting water at the door? If not, the filter is installed wrong or there is some packing on the filter you didn't remove.
Jan 10, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 53502 / 53504 Side by Side Refrigerator Logo
165 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
