Question about Garden
The engine shuts off when the wand handle is released.
    President:
  • 957 Answers
Could be that the idle is not high enough or there is a problem with the by-pass valve.
Posted on May 31, 2009
How do i release the handle on my dc25 dyson vacuum
Hi Dan, it's Jack at Dyson.
I'm sorry to hear you're having difficulty releasing your DC25's wand, but this is likely to be simple to resolve. It probably just means that the hose was twisted around when you last replaced the wand on the machine - allowing the hose to unwind will free up the wand. Just follow these steps:
I'm confident this will help, but if you'd like any further guidance after you've given this a try, you can reach our experts directly by calling the Dyson Helpline on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
Feb 29, 2016 | Dyson DC25 Animal Bagless Upright Vacuum
Cannot release handle or wand when I press the release button. .
We had the same problem.... we had to push both wand and lift way buttons together to make the wand release. I think it is a faulty button issue.
Jan 10, 2014 | Shark Rotator Lift-Away Professional HEPA...
I have a Honda GC160 motor on a powerwasher. The engine stalls when I release the power wand handle, but if i keep the handle squeezed, it works but the engine sounds like it is laboring.
replace the unloader of your pump....find the model of the PUMP ...not the washer itself...the pump and find a parts list and then purchase and replace the unloader. That will fix your problem. Good luck
Aug 15, 2017 | Honda Garden
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting www.dyson.com and clicking 'Support'.
Kind regards,
Jack
Dyson Online Customer Support
Aug 28, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
This is embarassing, but I have just looked at the Dyson DC07 manual and at my Dyson for about 20 minutes, and I can't for the life of me find the wand release button on my actual Dyson.....the manual...
Hi the wand release button is located directly above the the Cylinder release button. The wand release button looks like the picture below. In order to releease the wand you must firstly make sure the Electrical cable is not wrapped up for storage. So unwrap the electrical cable. then find the item as in the picture. Press this button in and at the same time lift the wand. This will realease the wand from the spine of the Dyson. dumfriesdon.jpg
Nov 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Engine stalls when I release the wand handle (stop water flow from wand).
this is because the pressure is wound up too high ,if you back the pressure off abit you will solve the problem. if your machine has a pressure gauge ,you will be able to see the pressure needle"spike" when you release the trigger.that is the needle jumps right up high that is when motor stalls if you adjust the pressureso that the "spiking" effect is minimal your machine will not stall ,..I hope that helps
Aug 14, 2009 | Garden
Pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Apr 19, 2009 | Campbell Hausfeld Garden
When I depress the handle on the wand the motor wants to stall
sounds like you have either a sticky unloader valve or a blockage causing back pressure to pump causing excess load to engine,a possibility is to check the nozzle at end of wand incase there is a piece of grit there since engine runs okay with no load,another solution is to check venturi that is located beside outlet of pump that you connect hose for wand to for possible wear or blockage,hope this helps
Mar 30, 2009 | Honda Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
