Question about Haier HC48C1VAR Central Air Conditioner
One unit runs a while, powers down, other unit blows transformer
Central a/c units. one unit keeps blowing transformer, other unit runs for hour or so, then completely shuts down for several hours
  • ktscolors May 31, 2009
    There is a transformer on the unit that controls power via thermostat to outside unit controls.
    "When you say "TRANSFORMER", do you mean the one on the light pole at the street??"
    -If I was blowing the transformer at the pole at the street, my house would blow up.
  • Ken Beccu May 11, 2010
    When you say "TRANSFORMER", do you mean the one on the light pole at the street?? There isn't any transformer on your A.C. system. There are capacitors, contactors, thermostats, that's it. No transformers I can think of on a 4 ton unit.
    Scholar:
  • 80 Answers
Probably a control board that has gone bad and keeps blowing the transformers! While testing just add an inline 3 amp fused link to keep from blowing the transformer and just fuses until you find out if the board is not working properly! The transformer is what converts the line supply voltage to 24v to control all the low voltage devices such as contactor/relay and reversing valves and solenoids! The other unit is overheating and tripping the internal overload inside the compressor. You can cool it down quicker with a garden hose and cool water running over it. Try making sure that the outdoor coils are cleaned free of debris and I would actually use some coil cleaner to really get them clean. Also be aware of the outdoor fan is running up to speed or at all in some cases.Replace fan motor if not! Change the Capacitor also! The run capacitor could be the culpret all together! $10 or so and may solve the over heating issue alltogether! Goodluck and hope this info gets you pointed in the right direction!
Posted on Aug 22, 2010
    Problem Solver:
  • 17 Answers
You say it keeps blowing the transformer? you mean circuit breaker? if it is the circuit breaker, have the wiring checked for a short, if no short do a ohm test on the compressor. it may have shorted out internaly.
Posted on May 31, 2009
4 Suggested Answers
  • 85 Answers
SOURCE: my furnace is blowing cold air
Is the a/c a heatpump also? Is the furnace gas, electric? Thanks
Posted on Dec 06, 2008
  • 17 Answers
SOURCE: 3 amp fuse blows after three hours on Goodman 4 ton 16 seer pump
I would suspect you have a problem in the defrost circuit of your heat pump. there are a couple of things you can try. first just run the system on emergency heat and see what happens. you could have a defrost board that is shorting when it kicks into defrost. it sends a signal back to the furnace so it will come on during defrost. if you do not blow a fuse as long as you are running in emergency heat, i would suspect the defrost control board. also you could have a dead short in the wire that runs from the "w" terminal on furnace control board, out to the heat pump. keep in mind that any of the wires could be the cause and i am just tying to give you the most common things. your furnace will still run if you unhook all the low voltage wiring out at the heat pump. if you do this and stop blowing fuses. you know it is something on that wiring. goodl luck.
Posted on Jan 27, 2009
  • 22 Answers
SOURCE: Unit will not cool below 76 degrees
Sounds like you need a freon charge on the unit. Check filtes for air restriction as well.
Posted on Jun 24, 2010
Asus laptop randomly shuts down
Possibly overheating. I would check the fan and airways are free from fluff.
Oct 06, 2015 | ASUS Computers & Internet
Samsung microwave keeps blowing fuses when not in use
The power transformer or the inverter board is defective, cost for parts will exceed the value of a new microwave oven.
Apr 09, 2012 | Samsung Microwave Ovens
My central air conditioner was working fine but the power went out for about 2 hours and when it came back on, my air pump runs and the air conditioner fan is running but it blows warm air. What gives?
mcdevito75 here, Your A/C units control board is most likely transisterized or computer built, in which case when power went out so did the memory in your A/C control board. Simply shut down your A/C unit, re-start and make adjustments again for your comfort.
Aug 19, 2010 | Heating & Cooling
Central air conditioning system is blowing warm air.
many, many. Is the outside unit running? If it is, is the compressor running? Feel the refrigerant lines leaving the unit. Little one should be warm. Big one should be cold, probably sweating.
Jul 08, 2010 | Ruud UAPA042 Air Conditioner
Keeps blowing the fuse inside the unit.
When a fuse blows suspect an overload in either the power supply or main amp stage. The most likely cause is some part acting like a piece of wire instead of doing it's job. In the power supply it could be the transformer, voltage regulator, or the rectifier or any diode. In the amp section any semi-conductor on the heat sink.
Check first for burnt or damaged parts. If you have a multimeter any transistor or diode will quickly show up. For when you have the meter on the ohms setting and touch the terminals with the probes, it will show as if you had touched the probes together.
Apr 02, 2010 | ButtKicker BKA1000-4A Amplifier
Behringer super x pro.the fuse keeps blowing on the ac inlet(t200 MA).a replacement unit works fine in the system.
When a fuse keeps blowing suspect an overload in either the power supply section or main amp part.
Look for burnt or damaged parts first.
The suspects in the power section are: transformer, diodes, rectifier, voltage stablizer, regulator.
In the Amp Section anything on the heat sink.
Jan 12, 2010 | Audio Players & Recorders
Heat side of heatpump is blowing a transformer when switched to heating mode.
It is either a shorted wire or a shorted component in the heat cycle wiring. The most likely is a bad reversing valve solenoid. You can use a re-settable transformer to help lower cost while troubleshooting. Remove the RV solenoid wires and set the unit for heat. If nothing blows,you will have found the problem. If it is not the RV,plug it back in and remove another low voltage wire and restart the unit. Keep doing this until the unit runs. When it runs OK,the last wire removed will go to the defective part.
Oct 04, 2009 | Ruud UAMB Air Conditioner
Central air system blows cool air not cold and
your indoor unit is only circulating the air in the house. for your condensing unit. check your breaker in the electric panel. your contactor or your capacitor.
Aug 09, 2009 | Carrier Heating & Cooling
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Haier HC48C1VAR Central Air Conditioner Logo
170 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
