Question about Sony KP-51HW40 51" Rear Projection Television
Screen Turns Red and then TV shuts off
My TV flashes red 3 or 4 times and then goes completely red and shuts itself completely off. the red led button flashes 6 times. any ideas what it can be?
  • 5 more comments
  • rescue26 Nov 07, 2007
    Hi my kp-51hw40 has same red flashes then shuts off ...my led flashes 8 times though ...can anyone pls help me...thanks Mike
  • carnivalbeta Nov 08, 2007
    my sony 51 in projection is doing the same thing . They said it would cost 560 to fix it. My red picture tube is gone! I am so pissed, this tv is only 6 year old!!
  • rescue26 Nov 08, 2007
    i see a solution is taping the color cannon and checking board for short but if its cooked,does anyone know part # for red cannon so i can price it...man sony blows.....thanks Mike
  • Anonymous Nov 11, 2007
    We have the same problem -- called Sony direct after repairman advised via phone the "bluetube" is shot and could not get. Sony said they would send a blue tube for $149. but cannot find repair person to install. Had 2nd repairman look at tv yesterday -$125.00 service fee and advised all 3 tubes are shot and it's a common problem. The cost of repair outweighs the value of the tv. Repairman said Sony is aware of problem and to contact them to see if they will compensate some of the cost -- waiting for a call back from them to see what they will do. This tv is only 3 1/2 years old.
  • Anonymous Mar 28, 2008
    the same problem but my light is blue
  • Anonymous Mar 14, 2014
    getting red flashing led- 4 flashes, any suggestions?
  • Anonymous Mar 18, 2014
    THE TV TURNS OFF ABOUT 5 MINUTES AFTER BEING ON....WHAT DOES 3 FLASHES MEAN??CAN U HELP ME...IS IT MY LIGHT BULB OR SOMETHING ELSE
    Sergeant:
    Champion:
  • 375 Answers
You red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Posted on Oct 24, 2007
SOURCE:
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
Sony kdl52xbr9 it comes on i can see picture and sound for a couple of seconds, then it shuts off and blinks 6 times
Hi! and Welcome to Fixya!
Blinking red lights on the tv are error codes that explains hardware issues on the tv.
However, if after turning ON the tv and you will see the Sony logo on the screen before the picture goes off and then flashes red lights for a number of times, this could mean that tv can still be recovered. Try the option below to isolate possible issue with settings that cause your tv to shut off. Disconnect first all external devices from the tv
1. Turn ON tv first and wait until it flashes the red lights > press and hold down the UP Arrow button ( use remote control ) > while holding down the UP Arrow button, press the POWER button on the tv > tv turns off, wait until it turns on by itself > release the UP Arrow button when tv turns on
Note: reset is successful when you see a welcome screen on the tv and ask you to select your Language. This is the Initial Setup, just follow the on-screen instruction
If that solution did not resolve the issue then a service may be recquired.
Let me know if this helps!
Oct 27, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Television won't turn on
If its a DLP tv chances are the bulb went out, double check with the manufacturer before getting as they are not cheap, around the $250 range.
Oct 26, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Turns Off By Itself
it helps , if you can tell me how many times the red led blinks , but for that model usually the hi voltage splitter cause that problem,
Jun 09, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
784 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
