Question about Panasonic DVD-S52 DVD Player
My dvd player has no audio sound at all daewoo dvd player perfect picture but no sound any ideas
    Sergeant:
    Champion:
  • 255 Answers
Is the connectors ok?try swapping your connectors.are you using a stereo amp?connect your rca plugs to ML and MR for stereo.check the audio settings of the DVD just to be sure.
Posted on May 31, 2009
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Audio is on but no picture
The problem is in the laser pickup, or the video processing circuits. I would change the audio/video cable to cover all possibilities.
Apr 21, 2012 | Daewoo DVG-9200N DVD Player
No sound on my AVD-S10 CD/DVD reciever.
just check up your rca chord maybe loose connection or defective rca chord. in audio only
Jun 19, 2010 | Sony AVD-S10 DVD Player
I dont get the sound, can see pictures.
hey sajith,
check all the audio and video cable's connected to tv and dvd player.
you may have forgot the wire color's (audio and video) there would be one wire for video and two for audio. some times there would be a RF socket also. so, see the right sockets and connect to tv by interchanging wires.
Dec 29, 2009 | Sony DVP-NS575P DVD Player
Daewoo combo - DVD is fine, sound works but not picture appears
The video heads have been clogged. You can try a cleaning tape, but those often do not work. If that fails, you will need to have a professional clean the heads and verify the head alignment. This should not cost more than $50 or so.
Dan
Dec 10, 2008 | Daewoo DV6T844B DVD Player/VCR
Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Sep 27, 2008 | Cyberhome CH-DVD 300 DVD Player
No audio from dvd player
you wil get the sound from the surround speakers only but not from tv first connect all the speakers that are given to the player correctly then you can get perfect sounds with dts...
May 04, 2008 | JVC TH-A25 System
No Audio when playing back certain DVD's???? HELP!!!!
Install AC3Filter ,This has solved many problems relating to sound http://prdownloads.sourceforge.net/ac3filter/ac3filter_0_70b.exe?download - binary http://prdownloads.sourceforge.net/ac3filter/ac3filter_0_70b_src.zip?download -
Jul 08, 2007 | LG XBR446 DVD Recorder/VCR
Samsung DVD M105
Try to service your dvd to a technicain or change your audio wires. If not successful, maybe your DVD appliance's chipsets are defective
Apr 14, 2007 | Samsung DVD-M105 DVD Player
Sound lags picture
This can some times be caused by VBR audio encoded files as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solved the problem.
Although this is usually with DivX (AVI) files that have been re-authored to DVD-Video I suggest that you convert all audio to CBR to avoid any such errors.
this conversion process it a bit of a long way around I know, but it does work!
1) Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
2) Ignore the error warning that the video contains vbr audio.
3) Extract audio as mp3 ("demux" in VdubMod or "save as wav", then rename to mp3 in VdubMP3).
4) Convert audio to wav with CDex
5) Open original video in VirtualDub, choose "direct stream copy" for video and "Wav audio" with "Full audio processing" with cbr mp3 compression (and interleaving with appropriate delay if out of sync) for audio.
You could also use several other methods including AVIDemux which uses VDub Mod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this doex not solve a progressive lag but can be used to reauthor a fixed error.
Feb 12, 2007 | Philips DivX DVD Player
Panasonic DVD-S52 DVD Player Logo
194 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
