Question about Motorola Mobility V365 Cellular Phone
My v365 has the message; unable to add contact,Invalid PTT number on the screen.When I press the right soft key to signify ok,it wont remove it.The contact does exist and is active and I am using it.The message not clearing is keeping me from getting to my PTT screen to make changes I need to make,like auto accept ptt and PTT on,etc. How can I clear this?
I have removed the battery,and simm card,and started and restarted the phone.I dont want to do a master reset,because it is a company phone and I have a lot of contacts in it and we bought them for the PTT cabibilities,which I can no longer access.
My side bar PTT is normal,can go to contact list and Ptt anyone,but my available icon at the top of the phone shows instead of a smiley face,the yellow circle with the rotating arrows like a PTT is still in progress even when I hit the end button.
Anyway to reset this?
  • beechboy Jun 24, 2008
    I have the same exact problem with my brand new Motorola V365 phone.
  • Anonymous Mar 24, 2014
    ptt contact problem. when it come on screen i can not any work.
  • 3 Answers
I had this problem and we needed to contact our cellular company to verify settings. After some time looking into the problem they said it was a hardware malfunction and swapped phones for us. I think there must be a solution to this problem that the cell representatives did not know about.
Posted on Jul 08, 2008
How do I text with Samsung Gusto 3 flip phone.
Create and Send a Text Message - Samsung Gustoâ„¢
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press OK.
  3. Select TXT Message then press OK.
  4. Enter the desired 10-digit mobile number(s) or email address(s) then press OK.
  5. Enter the message.
  6. To add a graphic, animation or sound:
    • Press the right soft key to choose Options.
    • Select Add then press OK.
    • Select a category (Graphic/Animation/Sound) then press OK.
    • Select an item then press OK.
  7. Press OK to choose SEND....
  8. try this.
Nov 22, 2016 | Samsung Cell Phones
When I try to save a contact on my palm pixi it just says "error." I can't save new contacts, I can only add to existing. How do I fix this?
You can add a contact that synchronizes one of your online accounts, such as Google or Exchange. You can also add a
contact in the Palm Profile account, which does not synchronize with an online account but is backed up daily to your Palm Profile.
If you are using Contacts for the first time, you go through a few different steps to get or access the contacts on your phone (see Using Contacts for the first time ). Follow this procedure to add contacts directly on your phone after the first time you use Contacts.
1. Open Contacts .
2. Tap .
3. (Optional) Tap the account button to the right of Name to change the account to which the new contact will be added.
4. Tap fields to enter contact details, select a ringtone for that contact, add notes, or add birthday details for the contact. Scroll to see all of the fields available for contact info.
5. In some fields, such as New Phone Number, when you enter the information a label button appears on the right. Tap the button to change the label for your entry-for example, to identify a number as a mobile or work phone.
Tip Use the Reminder field to enter that important message or question you have for this contact. The next time you send or receive a call or a message to or from the contact on your phone, the reminder pops up on the screen. You can also add a reminder later (see Assigning a reminder message to a contact).
Tip To insert a two-second pause in the dialing sequence, enter a T where you want the pause to appear. To insert a stop in the dialing sequence, enter a P where you want the stop to appear; to dial the next set of numbers after the stop, tap the screen.
6. Tap Done.
Oct 24, 2010 | Palm Pixi Cell Phone
I am unable to send text messages. Please help!
Contact your sim service provider and tell the message center number
Oct 13, 2010 | Nokia 7610
Using the fax machine of Panasonic KX FT981, how can i add a contact (including its number) into the phonebook ?
Panasonic KX FT981
I am unable to rcv fax message because memory full messsage is diplaying.
How to delete memory
Pls help
Feb 24, 2010 | Office Equipment & Supplies
How to text message
if you are new to texting then this phone is good for you as it has the full keyboard
to send a message with the phone, open it so you see the full keyboard
on the screen to the left you will see on the bottom it say "message"
click the button directly beneath it
choose 1. new message
1. txt message
you can now either type the number or add it from contacts (bottom right it says add, click the button underneath and choose from contacts and go through the list until you find someone you want to text. press ok and then press the button on the left under where it says done on the screen)
press the down arrow until you get to the body box and start typing what ever you would like to text
then press the OK button and you are all set... you have sent your first text messagE!!!!
Nov 09, 2009 | Verizon Communications LG enV Cell Phone -...
How do you sent an SMS message to multiple recipients on the iPhone
Go to the Test Messages screen (touch the SMS button) and then touch the Compose Message button at the top right hand side of the screen (Do not start by using contacts or favorites or another way).
I opens a blank text message with the "To: " at the top.
Start to type the name of the contact (below you will see the contacts that match. At any time you can select any of those by touching them).
To add the next contact touch the "+" to the right of the first contact. It will open your contacts and you can select another or you can just type in the number of the person you want to add to the text message.
You can keep repeating this until you have them all in there.
When you have all the desired contacts in there, push "Send"
Dec 31, 2008 | Apple iPhone Smartphone
N95 message centre number
hello willdee
best thing is to contact your sim operator and check with them if you have the correct settings for sending texts.
there they should give you the correct number to send txts.
May 14, 2008 | Nokia N95 Cellular Phone
unable to save contact to my phonebook.
Jan 01, 2008 | Motorola Mobility A1200
Motorola Mobility V365 Cellular Phone Logo
148 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
