Question about Welding Tools
No wire feed when pulling trigger. also no arch when touching tip of gun to ground. even took wire out and motor doesnt try to run.
    President:
  • 957 Answers
Check the contacts inside the trigger.
Posted on May 31, 2009
Hello, I have a Hobart 180 and the wire feeder motor won't run. I replaced the wire feed motor and it still won't run. any ideas?
Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
Jun 27, 2011 | Hobart Welding Tools
THE WIRE CONTINUOUSLY FEEDS THROUGH THE GUN EVEN WHEN IM NOT PRESSING THE TRIGGER. IT JUST KEEPS COMING OUT
The trigger engages a relay that starts the feeder motor. Make sure your trigger is not stuck. Listen for a "click" when you squeeze it. Next, take the side cover off and look at the motor relay. If needed, remove the motor wire from the relay and try it again. My guess is the relay has arched shut. Please let me know how this works out.
Roger
Apr 03, 2011 | Clarke Power Products Welding Tools
My Hobart Handler 120 stopped working during a welding process. Now when I pull the trigger, the 30a 110v circuit breaker trips. The machine can be turned on and the breaker holds (cooling fan in the...
Please don't give me a bad rating for this. Its just a little extra info. you didn't mention that may help you find the problem. Depending on your specific model, there should be 1 or 2 breakers on the unit it self. If there is only 1, it will shut down the entire machine when tripped. If there are 2, the top one is for the whole unit and the lower one is for the wire feeder motor only. There is also a thermal overload that will shut down everything except the cooling fan. Secure the trigger closed and let the fan run for a while to see if it re-starts when cooled. If the depth of the weld was stable before the problem occurred, I would suspect a short in the motor and not the rectifier. That is not a sure bet though. If the transformer does not start when it cools, UNPLUG the welder and short the transformer to ground to be sure the capacitor is discharged. Then isolate the feed motor and transformer and use an OHM meter to test them individually to ground for a short. With a little luck, it will be the feed motor. Please let me know if this helped at all. I am new and still learning how to explain what I am thinking. Thanks for writing us.
Roger
Apr 02, 2011 | Welding Tools
My hobart handler 120 will not feed wire. took the feed motor off and tested. Its good. checked the trigger connections and they are both in good shape. The gas valve does click when the trigger is pulled....
First take our the spool of wire, then without any wire restriction, disconnect the gun from the machine and bridge the trigger connection, if the solenoid valve opens then the motor shoulod run. If it does, then check the trigger on your gun, take it off and bridge the cables, if it runs then your trigger switch is faulty.
Dec 28, 2010 | Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
How do i solder together some headphone wires?
1- pull the trigger and melt some solder onto the tip then release the trigger.
2- hold all the wires together.
3- touch the tip to the wires and pull the trigger. when the solder on the tip melts again it will flow onto the wires
Jan 16, 2010 | Weller 8200 Soldering Gun
Pull the trigger ,air comes out no fire
Ck the ground and the condition of the tip. The more it gets concave the harder it gets to get a arch. Gun angle is also important, hold at right angle to work and don't forget a very good ground.
Nov 03, 2009 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
Northern tool mig welder,120 volt with gas.The wire feed is not working.When i pull the trigger the wheel that feeds the wire to the gun does not spin,even with no tension on it.The fan works and the...
you are going to need to remove the wires going to the wire feed motor, then take a volt meter and check the wires when you pull the trigger. this will tell you if the motor is bad or another problem
Apr 14, 2009 | Welding Tools
No arc for craftsman professional wire feed welder
either your not grounded on the vehicle very good or you lost the ground either in your gun or on your clamp
Apr 04, 2009 | Welding Tools
Welding Tools Logo
110 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
