Question about Sanyo HT32744 32" TV
Screen has green and reddish spots in two upper corners
We had two large speakers next to the TV, but we moved them about six months ago and occassionally still have spots on the screen.
  • jptryan Nov 14, 2007
    I have same model. I had the green problem when I first got it but moving the speakers seemed to do the trick (magnetic interferance?). My tv is also almost 2 yrs old and the last 6 months has begun to turn red for periods of time. sometimes turning on and off the tv will help but it's a real irritant. Tonight the entire screen turned black on three sides and pulled in from the sides. after 40 min it went back to normal. Sanyo won't stand by fixing whatever is wrong. I've had tv's that have lasted 20 years that didn't give me a lick of trouble. Any ideas?
  • 2,130 Answers
It sounds like the screen has become magnetized by the magnets in the speakers.
Inside all analog TVs is a device called a degaussing coil. When you turn on the TV for the first time (cold), the degaussing coil is energized for a couple seconds to demagnetize the screen and then it goes off.
You can purchase an external degaussing coil and demagnetize the screen youself. A degaussing coil looks like a small hula-hoop about 6-8 inches in diameter with a AC line cord attached. I've even made these coils out of long lengths of enameled wire, electrical tape and a line cord.
Once itas plugged into the wall outlet, you hold it close to the screen (1/2' away) with the hoop facing the screen and move the hoop in a circular pattern, covering all areas of the screen and slowly move the hoop away from the screen while still moving in a circular patten until your about 2-3 feet from the screen.
If you did it right, the color splotches will be gone.
It's possible that the coil in your set is bad. The coil is energized for a few seconds when you turn on your TV and then it shuts off a few seconds later. You can try turning on the set for around 30 seconds, and then turn it off. Wait about 10 minutes and turn on the set again. Doing this several times may let the sets internal coil (if its working) to demagnetize the screen. If not, you'll need to use a degaussing coil.
Let me know if I can be of further assistance to you.
Good Luck!
Posted on Feb 10, 2008
Thanks for the solution. I'll give it a try. Also, I have surround sound and don't need the speakers in the set. Would it work to remove/disable those speakers (i.e. will that get rid of the problem permanently?)? Second is it practical to do so?
Thanks again for offering me some hope.
Light green and pink spots on my hd tv!!!
You really need to be persistent. I went on the Panasonic customer support webseite and started a web exchange. The first two attempts ended with "call your local authorized service tech" , etc. The third time, I described the prolem again and asked if the authorized tech would have the tool to fix the eprom if that was the cause of the problem. They finally gave me a name for their scheduling department and said they would pay for the diagnosis. I was pretty happy about that, but even happier when they said that this was a known problem and they would pay for the repair as well. They scheduled a service call. The techs came and fixed the eprom error with their tool within 1/2 hour. That was about 5 weeks ago, and all looks good so far.
Aug 27, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Color distortion
Move any speakers or electrical devices away from the set. It could also be anything electronic or magnetic. Anything near the set that generates a magnetic or electromagnetic field could be causing the distortion.
Jun 04, 2008 | Zenith A36B41W 36" TV
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My picture was distorted by a speaker magnet
well , yes , you have to purchase a DEGAUSSING COIL to take care of this problem and know how to use it (which its very easy) available at electronic stores (try EBAY) What you do is you place the DEGAUSSING COIL in front of the color spot and do circular motions while slowly stepping away from it . that should take care of that.
Apr 12, 2008 | Panasonic CT-34WX54 34" TV
Color problem
is there a speaker ( other than built in ) near the tv? ( if so, move speaker away from tv.
Dec 13, 2007 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Red/green drooping L top corner
i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
If you have external speakers near the TV they may cause this problem. Moving the speakers away from the TV and demagnitizing the set will fix the problem.
Sep 03, 2007 | iLO 3200 32 in. LCD Television
Sanyo HT32744 32" TV Logo
123 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
