Question about Kenmore 62602 Electric Dryer
Whirlpool dryer timer clicks but doesn't turn the dial.
Of course the dryer will not turn off. Any help appreciated My timer when set doesn't move or click but the dryer still works. I have to manually turn the dryer off when the clothes are dry. What could be wrong?
  • cmeginniss May 31, 2009
    the timer motor has 120V when it's in timed cycle, but not the auto dry cycle. The contacts seem to be opening and closing though because when I manually spin the dial to off, it shuts off the dryer. Is it still most likely the timer?
    President:
  • 1,136 Answers
Hi, It sounds like the timer is going bad. If you remove the rear panel and locate the two black leads that go to the timer motor, Check and see if it is getting 120V. If there is voltage to the timer motor and it isn't advacing, you need to replace the timer.
I hope this helps you. please let me know if I can assist you further.
Thanks
Vic
Posted on May 31, 2009
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool dryer timer clicks but doesn't turn the dial.
Bad timer. Replace it.
Posted on May 26, 2009
Our Whirlpool Dryer Will not heat at all and not
Your timer may be the cause of both problems. Not cycling and no heat.
Whirlpool makes a excellent dryer and is worth repairing. Replace the timer first. If you still have a heat problem most of the other parts are around $30.
Nov 09, 2009 | Whirlpool Dryers
Dryer does not heat
when your dryer does not heat the timer will not advance, check the heating element and the thermal cut out kit
Jun 25, 2009 | Whirlpool LER4634J Electric Dryer
Dryer drum won't rotate
if there is no air coming out of your vent on back of dryer then it would be likely your motor has gone out.
Jun 24, 2009 | Dryers
Dryer drys but the timer dial does not turn to stop automatic
Hi, You will need to change the timer. The timer motor has gone bad. You can test it by removing the back cover on the control panel and test the two wires going to the timer motor to see if it is getting 120V. If it is getting voltage, it should turn.
Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LER5636P Electric Dryer
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Dryer won't start, Simpson Eziloader 4kg
Yes, the knobs don't like to be turned counterclockwise. Spin the knob clockwise to reinstall tightly, then move to set a dry time. Make sure half load button is pressed.
Jan 24, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore 62602 Electric Dryer Logo
301 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
