Question about La Pavoni Europiccola EPC-8 Espresso Machine
I only get foam after 4 Shots
The first four shots come out of my machine just fine, but if I try to get more without refilling, water and foam just kinda spurt out of the spouts. I used to be able to get eight just fine. It's a really old model, but I had it totally serviced about a year and a half ago.
  • jakehrosenbe May 31, 2009
    Thanks for the advice, but I descaled it a few days ago and looking in through the top it appears to be clean as a whistle.
    President:
  • 1,618 Answers
The only thing that comes to mind is descaling. To me it seems that most of the boiler room is being lost to minerals, so there is less water in there. Try descaling the machine.
Posted on May 31, 2009
  • Ernest R
    Ernest R May 31, 2009
    Since that is done, then the next option is the heat on the machine, on some models there is a gauge, make sure it is not going past 1.2 bars. Also you can check the thermostat on the machine, check the breakdown below for a better view of machine. I know it is different from your model, but the concept is the same(La pavoni makes all home lever machines and just stamps a different label on them).
  • Ernest R
    Sorry I did not add Pic
Why won't the shot buttons on my Aurelia stay depressed and allow shots to be pulled?
Sounds like the keypads need to be replaced. As for the left head the jet in the flowmeter is blocked.
Jul 23, 2014 | Nuova Simonelli Coffee Makers & Espresso...
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
Ascaso Dream water leak & bad shots
Hi
Sounds like you have a leak in the system. If your handy, you can remove the top. Remove everything. Water tank included. Unplug the machine. Now turn the machine upside down on a towel. There are 2 screws behind the brew head. Remove them, then lift the machine off the top and set it right side up. Now you can see the inside of the machine where the boiler is. Do not touch anything inside the machine. Replace everything and plug the machine in. Now turn the machine on and try to make a shot the same way. This should show you where your trouble is. Once you see where the trouble is, unplug the machine. Contact seattlecoffeegear.com, or 1st-line.com. They can help.
Jul 29, 2009 | Ascaso Dream Espresso Machine
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Automatic astra II pulls a few great shots then error light on
The error light usually comes on when there is no water flow through the group after about 5 - 10 seconds, indicating a clog of some sort. The fact that it happens after two shots, however could indicate an issue with the processor. The problem with the steam wand could also point to a clog situation, especially in the other wand is working. First, try running shots through the problem group with no grounds at all in the portafilter; Say five or six shots if you can to see if you get the error light. Look at the water flow in the process: The water should just pour out of the portafilter. If the water is running freely and you still get the error light, you are probably looking at a processor/sensor problem. If not, it may just be a restriction. Remove the screw from the middle of the group head (the diffuser), and remove the screen and the brass plate and check them for clogging. You really want to wait until the machine is cold before you do so as the parts will be extremely hot. As for the wand, try removing it, and check it for obstruction.
Nov 24, 2008 | Astra Mega II Espresso Machine
Coffee watery
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 15, 2008 | Saeco Caffe Charisma Espresso Machine
Rancilio producing very very slow shots...even when no portafilter.
from your description i can conclude only 2 things:
  1. coffe grinded too fine
  2. pump pressure low
i think you can chek these 2 and have your perfect espresso again
Jan 19, 2008 | Rancilio SILVIAespresso&cappuccino machine
Weak coffee shots
Need a decent grinder or a deft hand with a blade frinder, fresh espresso coffee beans and not too much water. Espresso grind is closer to turkish than drip. Much like Melitta grind. If needed a good coffee shop will grind it for you. A week suppply is preferable. If quantity of water can be adjusted, one shot is about 1&3/4 oz. a double shot, well x2=3.5 oz. You cannot get a six ounces espresso and still call it that; its dilluted or "allonge". A latte w/o milk. Let me know
Dec 29, 2007 | Saeco 762111651808 Espresso Machine
Shots are small, and water leaks from bottom of unit
You machine has an internal leak and this is why you shots were getting smaller and smaller. The more time goes by the more it leaks, hense, the reason for smaller shots.
You should have someone look at your machine.
Saeco Service Center for New York
www.cerinicoffee.com
Nov 21, 2007 | Gaggia Syncrony Espresso Machine
La Pavoni Europiccola EPC-8 Espresso Machine Logo
187 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
noel
noel
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
