Question about Miele Premier-Plus Built-in Dishwasher
Door problem Hi, I'm not sure of the model number but our Miele dishwasher has a very tight springback action on the door. This must be adjustable but I cant work out how! It is very tricky trying to load and unload when the door wants to spring closed all the time! Thank you, Sue
  • rayenw Oct 28, 2008
    I cannot keep the door open. Tried to loosen the two screw holes below the door but they don't make any difference. Model G1xxx
On my machine there is a torx screw at the top left hand side. You need to open the door to see the screw which sits behind the off-white flange (look for a hole in the flange).
Posted on Nov 05, 2007
  • experiment26 Jan 13, 2011
    This is described and illustrated on page 18 of the manual - seehttp://www.miele.co.uk/products/manuals/...
    The door should be opened to 45 degrees before adjusting the springs
How do I fix my new Miele dishwasher door springs?
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please provide model number
Jul 30, 2014 | Miele Dishwashers
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
I've just installed a Miele 5500SCU Dishwasher and the springs that support the door cant be adjusted far enough to take the weight of the door, does anyone have any suggestions?
If the dishwasher is brand new, then there is an issue with the configuration of the springs, i.e not mounted correctly. A factory dishwasher door should not need to be adjusted. However if it is older, it is possible that the springs came off, in which case they can be seen from the underside of the dishwasher and by a panel that unscrews on the bottom of the door. Make sure the springs are there.
Dec 30, 2012 | Miele Dishwashers
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
Can I purchase a new door for my Miele LaPerla dishwasher. The current door has 2 dents.
You certainly can replace them, one would require the model number La Perla G28XX (eg) as it also comes in assorted colours, downside is that its mostly only available from Miele or an agent.
Jun 18, 2011 | Miele Dishwashers
23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
May 18, 2010 | Miele 23 in. Novotronic G841 Built-In...
Miele g 851 sc i have a leak under the unit (below the right door hinge) when i run the machine
hi,
make sure you are not using too much detergent. no more than 2 teaspoons. try running the unit with no detergent a few times. if problem still persists then check the door seal or remove the door panel and make sure the overflow tray running along the base of the door where the hinges are is not blocked with food. also check the door is closing enough to seal,the door latch may have moved. check the tightness of the screws
Nov 20, 2009 | Miele 24 in. Novotronic G851SC Plus...
Can't find service or parts manual for Miele G843SCVi
They keep their manuals pretty tight. The only way I know is to know someone there or a service centre that deals with them.
Sgt 48
Feb 21, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Premier-Plus Built-in Dishwasher Logo
974 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
