I have a spa city ''superpac'' deluxe series M30 model hot tub in the home I am staying at (we just bought this home and the hot tub came with it) however the instructions are really not helpful and it does not tell me where the power (on) button is - I looked all over and around the hot tub for the button and I can not find it. Could you help me? I am not sure how to turn the hot tub on and it is getting really cold please help me
If you have a hard time figuring out how to turn on your hot tub the first time, don't worry. It can get confusing. Most of the time, the trick to figuring out how to turn on a hot tub is knowing how to use the right switches. Before you turn on the hot tub, it's a good idea to test out the jets first. Find the switch that turns on the jets and switch it on. Once you've done that, turn on the gas and check to see if the water fills up. If it does, you're ready to get in. If the tub doesn't fill with water, press the reset button. It's usually on the outside of the hot tub. If that doesn't work, you may have a more serious problem.
If you are reading more about hot tub related please visit this site: https://hottubpatio.com/
Hot tubs do not have an "on" button. They are preset to heat up to 100 as soon as the breaker is turned on.
SOURCE: how to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
no sorry the hot tub is out side and I checked the breaker everything looks good but I still cant figure it out and I can't find the manual anywhere I have been looking for two days it is driving me nutts
Well, I think by code the hottub has to have a dial/timer switch on it. If the tub is a good distance from the house, the switch will likely be under a waterproof flap on an electrical box sticking out of the ground. See anything like that?
Do you see a dial on the wall in the room anywhere?
