Question about Quasar SP-3235 32" TV
Quasar tv atenna/connector broke on tv
Cable/atenna connector on tv broke off... sound and snow is all i get now..... is there some means of being able to use the tv and hooking it up to my cable box without calling a tech out to fix it? Or if not, how would a person fix it step by step (or diagram showing how)
  • sandyjoellio May 31, 2009
    so where would the cable from the box go? would you have to have a dvd player hooked up as well?
  • 26 Answers
Yes if your cable box has RCA yellow, white, red, outputs on it and your tv has RCA inputs on it you can hook it up that way. It'll only cost you one set of RCA cables which are not expensive at all.
Posted on May 31, 2009
My lg tv has sound and no picture. Has back light I checked with flashlight. Replaced boards in back turned it on had snow. Finally hooked it up to cable and it went back to sound and no picture.
There must be something loose on a print board as i read that it was giving a snow picture after replace boards and if you disconnect the cable it does also not snow again begin in the basic powersupply and the boards after that you have not replaced first and then gently press heat-carrying components specifically which sit on a heatsink but also connectors with a
plastic or other non-conductive object.
Mar 02, 2016 | LG Televison & Video
How to replace front auger cable on a snow blower
This picture is from an MTD but it should be the same.
Feb 16, 2016 | Garden
No picture, but sound
tried to hooked up with an air antenna. if you can not get any channel and just a white raster or snow, it could be the tuner get fried.
Jul 22, 2012 | Sony KV-32S45 32" TV
How do I hook up the atenna to cable
Do you mean 'cable' like in 'cable TV'? You don't.
If you want TV-related sound a cable box, dvr or sat box will be the best source of it and will have at least stereo analog audio out, probably multichannel digital, too. Use whichever works best.
Dec 24, 2010 | Insignia 200W Stereo Receiver
My Panasonic DLP television suddenly lost picture, went to snow and lost audio. What is wrong?
If you have snow that means you've either lost the signal source (cable satelite antenna) or the TV tuner is bad or your not on a recievable channel. Try hooking a signal to one of the video inputs of the TV.
More info on what you have hooked to the TV would help.
Sep 27, 2009 | Panasonic Televison & Video
The female cable connector on the back of the tv broke off
yes,you could also use RCA cords from the cable box to the tv and bypass that by selecting the video channel that you hook the rca's to
Jun 02, 2009 | RCA TruFlat 27F520T 27" TV
Vcr picture problem
clean the heads. check out my tip
Nov 02, 2008 | Orion VR213 VHS VCR
Great Picture But No sound
Good Day;
Look in owners manual pages 28-35, pay special attention to page 31 and make sure the antenna is connected to ANT-DTV input. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Antenna hookup broke off
You have to re solder the connector. The other solution is to patch from the Direct TV box AV out to the AV input on the back of the TV. This will bypass the tuner and give you a cleaner picture. However, if your TV does not have an external input you must re solder the connector. As easy as it may seem, this should be done by a qualified technician. Its not as easy as it looks and requires good soldering skills.
Nov 12, 2007 | RCA F19207BC TV
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
Quasar SP-3235 32" TV Logo
168 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
