Question about Funai Emerson DVD/VCR EWD2004
BUILT IN DVD PLAYER WON'T OPEN AND TRAY WON'T SLIDE OUT.
THE BUILT IN DVD PLAYER ON MY EMERSON TV WILL NOT OPEN. NOTHING IS STUCK IN THERE, THE DOOR WON'T OPEN AND THE TRAY WON'T SLIDE OUT!
Samsung v8500 dvd stuck
i can understand is this trays is stuck. see the steps and fix it.God bless you.
  1. Open the housing by removing mounting screws and anything blocking the tray. Press the open/close control to the extend tray, then unplug the unit. To remove a clip-on tray front, brace the tray and slide the panel to one side.
  2. Unplug cables between the front panel and the interior. Remove any screws securing the front panel and remove the panel. If it won't move, check beneath it for clips or additional screws.
  3. Remove the hold-down on top of the disc tray and gently pull the tray out of the player. Clean the travel rail and guides with a swab dampened with denatured alcohol. Lubricate lightly with white lithium grease.
  4. Remove the drive belt (using gloves or tweezers) to inspect for dirt, water, or damage. Clean with a lint-free cloth moistened with denatured alcohol. If the belt is damaged, replace it.
Oct 03, 2012 | Samsung DVD-V8500 DVD Player/VCR
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
THE dvd WON'T COME OUT OF THE dvd PLAYER AND THE
tere should be a little pin hole somewhere on or near the dvd player. take a paper clip straighten it out and put it in the hole you will have to push hard until the dvd holder pops out a little then pull it out until it stops. remove the dvd and push it back in then try to open the slot using the open button. it it doesn't work then you will need to take it in for repairs or replace the tv. though it would probably be cheaper to replace the tv.
hope this helped
please rate well.
Mar 06, 2009 | Emerson EWL20D6 Television
Dvd recorder stuck in Repairing Mode
I don't see any opening hole to retrive the CD inside the best option we can do is to open the the cover chasis and pull out the cd on the tray.
Thanks,
Mar 01, 2008 | Emerson EWD7003 DVD Player
Will not play my dvd-r
Is the media a compatable format? DVD player might play video cd's but not .WMV's for instance....
Sep 09, 2007 | Emerson EWD7004 DVD Player
Door will not open or close
i ended up retrieving the dvd out of mine after it quit coming on by taking the top cover off and taking the cover off the dvd it just snaps in place by clipping on each side.
Feb 17, 2007 | Emerson EWD7003 DVD Player
DVD tray will not eject
go to the any depanator and help to zero(.)settyng your dvd
Nov 28, 2006 | Emerson SB350 13 in. TV/DVD Combo
Televison & Video Logo
358 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
