Question about Philips 37PFL5332D 37 in. LCD Television
High frequency chirping noise
Phillips LCD model #37PFL5322D The TV makes a high frequency chirping. The sound is coming from the center of the back of the unit, and the intensity and pitch of the chirping seems to change every 30 seconds or so. Sometimes, there is no chirping at all and it sounds normal. Any ideas?
SOURCE: Phillips 30" Mod 30pw633r37a
I unplugged it for 24 hours. When I plugged it back in it was ok. It has done it a couple of times since, but only for a few seconds.
Posted on May 14, 2007
SOURCE: TV HAS HIGH PITCH SOUNDS
THANK YOU FOR YOUR HELP!!!
Posted on Feb 07, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Posted on Feb 04, 2009
SOURCE: phillips tv 42pfl3603d/f7 when I turn on it makes
signal board
Posted on Jan 07, 2010
SOURCE: PHILLIPS PLASMA TV MODEL #42PF9431D/37 Heard
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
Posted on Apr 01, 2010
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Lcd32f 1080p
There is only one possibility of noise [high-frequency] to LCD TVs. It should be coming from its back-light inverter board. The ferrite cores of the inverter transformers at the back-light inverter board can make this noise; if there is any loose fittings. Check it.
Gopakumar Gopalan Google
Apr 22, 2014 | Bush Televison & Video
Model 37PFL5322D/37 phillips tv has a chirping sound, no picture
Your TV is exhibiting a symptom of power supply trouble but repair is not a casual task.
Dec 20, 2013 | Philips 37PFL5332D 37 in. LCD Television
My tv started to hum have figured it to be part of the backlight NEED HELP?
Hello Sir, Hi, if that is the case, your inverter board is generating audible high frequency noise. the inverter board is true to produce high frequency pulse needed by the LCD, but if should not be audible. try replacing the inverter board and see if the noise will dissapper .
Jul 17, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
Model 37PFL5322D/37 phillips tv has a fast clicking sound in the power supply, what will cause this.
possible the main relay in the power supply board may need soldring or you could have a stickey relay
Jul 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
High pitch frequency noise coming from rear of TV and is very annoying to listen too. It is a constant noise and is more apparent when there is more black color on screen.
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No sound from Phillips 37 LCD
The audio output IC is probably faulty this cost only a few dollars if you replace it your self.Let me know if you need further assistance or more information.
Mar 30, 2008 | Televison & Video
Samsung PCL542R Chirping noise
There is problem in sound IC. First check it
Feb 17, 2008 | Samsung PCL5415RB 54" Rear Projection...
No picture or sound - TV makes chirping noise
The chirping sound is the power supply coming up then breaking down because there is a short somwhere in the high voltage. The most common fail in this area is the horizontal output is shorted ( 237470 ) but what cause this short could be simple cold solder joints or the High voltage transformer ( 239111 ) If you have noway to "ring" the flyback change both parts
Feb 13, 2008 | RCA Scenium D40W20 40" Rear Projection...
Samsung PCL5415RC Chirping noise
power supply discharging.even after the set is unpluged.
Sep 13, 2007 | Samsung PCL5415RB 54" Rear Projection...
Philips 37PFL5332D 37 in. LCD Television Logo
419 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
