Question about Mobility Optical Mini Notebook Mouse w/ Retractable USB Cord Retail (MSOUSBICNTBKBS)
Mode NO. M00117-MB
My notebook starter kit has a mobility mini usb retractable optical mouse mode no. m00117-mb. the mouse is not moving the curser at all but the computer says that it is able. the little red light is not very bright.
  • 3 more comments
  • brutcher Oct 22, 2007
    please help
  • Anonymous Feb 29, 2008
    Just bought one of these on sale cause it looked clever. Too clever by half it would seem - cursor only moves in horizontal direction, no vertical movement!
    Tried on Mac and PC, same result. Seems like cheap junk at this point. I opened it and found optical chip OM02, spec here:
    http://www.avrvi.sdu.edu.cn/avr/xinpian/...
    when I have time I may examine the solder pathways to see if there's been an assembly defect. Otherwise it's e-waste.
  • Anonymous Sep 03, 2008
    Just bought one of these and Vista will not install drivers for it. I keep getting an installation error. Do not buy this mouse! It is cheap junk!
  • Chris Yost Oct 09, 2013
    I have one attached to my Vista system via KVM and it works just fine.
    I have one attached to my Vista laptop via a KVM switch and it works just fine.
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
Connects and clicks just doesnt move the curser
I presume you can see the motion sensing red LED or laser beam shining under the mouse. If not, that has gone bad, and it would probably be more economical to replace the mouse than to attempt a repair.
If the light is on under the mouse, try cleaning the lenses (both LED and photoreceptor) with a cotton swab dampened with isopropyl alcohol (rubbing alcohol). Don't scrub, just wipe the optics gently until clean.
Nov 11, 2017 | Belkin Mini Wireless Optical Mouse...
Mouse driver for m00117 laptop running win 7 does recognize mini mouse need driver
click start control panel under harware and sound view devices and printers you should see your mouse right click select open download mouse software
once your usb mouse is connected windows 7 should automatically search for and update the drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question/exclamation mark? ! or a red Xthis means a driver will need to be updated right click select update driver
Oct 18, 2011 | Sakar Optical Retractable USB Mouse...
Free download of drivers for moserbaer optical mouse model no mb 2135a
http://download.cnet.com/wireless-optical-mouse/3000-18491_4-74574.html
http://download.cnet.com/mini-optical-mouse/3000-18491_4-66771.html
if these driver packages are not right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
also this link will provide you with many freeware and share drivers
hope this helps you
Aug 24, 2011 | Computers & Internet
I bought a cordless optical mouse put the batteries in and pluged the mini reciever in the usb port but I can't move the curser what am I doing wrong?
Did you turn the mouse on? I forgot to turn mine on :-) maybe you did to? Tiny switch on the bottom.
I hope this solves your trouble.
Apr 01, 2011 | Computers & Internet
My mini wireless optical mouse will not pair
I think you are facing pairing problem, solution is here, First of all please understand ‘what is pairing’ Pairing is theprocess of coordinating your mouse's transmitter with your mouse's receiver. Itrequires both parts to operate on the same frequencies, usually by using thesame identification code. Pairing takes place to try to eliminate interference.Some devices automatically pair both devices at start up; others need to bemanually paired. Step 1. Plug in RF DONGLE into USB port, Step 2. Put the batteriesin mouse (in right direction, see batteries. Direction symbols in the battery compartment +/- signs) andplace the batteries. Cover, Now you can see thered light glowing on the bottom of the mouse, now your mouse is ready topairing There is two buttons for pairing the mouse BUTTON 1 – this on the RF DONGLE, top/up side BUTTON 2 - this is at the bottom of the wireless mouse, NOTE- after pressing button-1, one time, your RF DONGLE willbe ON SERCH MODE for 7 seconds, Step 3, now press BUTTON 1, one time, and move the mouse, ifmouse curser is not moving then press BUTTON 2 one time – now defiantly yourmouse will work, If you need any other technical support for GMAX, products please contact satish kumar (countryhead gmax technologies)
Mar 08, 2010 | BenQ M310 Wireless Mini Optical Mouse
Hi. My Belkin Mini-Wireless Optical Mouse has stopped working. The batteries are fresh but no curser working - any ideas? Rgds
Please connect the mouse to another computer to rule out if the device has failed. If it works on another system you may be dealing with a messed up driver. Please comment this posted on your test results to receive the best answer.
Thanks
Live-Tech 1-888-361-8511
Jan 29, 2010 | Belkin Mini Wireless Optical Mouse...
M00117-MB right click button doesn't work
My problem is with the left click. I buy there mouses because they're cheap, but I suspect foulplay: Planned obsolescence! They always start to break down after a while for apparently no reason and then you're off looking for a new mouse, but then again I could wrong, maybe they're just generally not built to last or for heavy usage.
Next time I'm doing my homework on which companies make quality mouses so I won't have to keep replacing them - I suggest the OP and others who have problems with Sakar do the same.
Jun 30, 2009 | Sakar (01717) Mouse
My computer does not accept the new mouse model no. M00117-MB. Can you help me?
If your computer does not have a USB port on the front or back, you will need to purchase a USB-to-PS2 adapter. This is an example of one:
http://sewelldirect.com/ps2tousb.asp
That may not be the best price or only place to get it, only an example. This will connect the USB cable of your mouse to the PS/2 port on the back of your computer.
Jun 10, 2008 | Computers & Internet
Computers & Internet Logo
396 people viewed this question
Top Mobility Computers & Internet Experts
David Payne
David Payne
Are you a Mobility Computer and Internet Expert? Answer questions, earn points and help others
