Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi WS-55909 dm board repair
Green light comes on for about 3 seconds then I hear a click from the back of the TV. No picture or sound. I've used the reset button, green light blinks for about 1 minute then goes off. Owners manual says to turn on set after light goes out but set will not come on. I havent been able to locate your posting on fixya about how to locate and repair dm board. Thank you TV was on, and all of a sudden clicked off. Now, if you turn it on, the green light comes on, no picture comes up, and then it has audible clicking sound, and green light goes off. I've pushed reset, unplugged, etc, and no luck. i tried the menu and input button test that was posted. i had 10 double blinks with pauses between a set of double blinks. total of 5 sets of blinks. and nothing yet. can you help
    Problem Solver:
  • 11 Answers
I have the same TV and the error light code on my set is 22
Posted on Dec 13, 2009
  • Mitsubishi Master
  • 8,617 Answers
You dont need to repair the DM, as its working fine if the led quits blinking, your set wont start because its shutting down. If you hold in the menu and device/input buttons both in together on the front of the set for 5 seconds. The led should blink a two digit error code which will let you know what area of the set has the problem. The light will blink a series of blinks then pause briefly and then blink another series of blinks for the second digit. Let me know what the two blinks were and I can assist you.
Posted on May 31, 2009
I had the carpet replaced in my home and the tv was unplugged for a short time , when I plugged it back in the timer light is blinking green. It will not power on, it just blinks green.
Thats caused by weak DM capacitors. They discharge when the set is unplugged even briefly then they cant recharge after getting power restored. You can get the Mitsubishi DM repair kit for your model at www.tvrepairworld.com which contains the caps and the CD with repair instructions.
Oct 23, 2011 | Mitsubishi WS-55909 55" Rear Projection...
Unplug tv for 1 week for vacation plug tv in &green light doesnt stop flashing.never had problems ever.
Thats a common problem caused by failed capacitors on the DM board. Usually after unplugging the set the capacitors drain down then when you plug it back in the Caps wont charge and you will get the constant blinking light. You can get the DM repair kit for your model at www.tvrepairworld.com under the mitsubishi repair kit catagory. The kit contains the Capacitors and the CD with instructions for the repair.
Dec 01, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi ws-55613 green light blings rapidly and TV will not come on.
The DM module has bad capacitors in it and these will need to be replaced, or the DM module replaced.(about 85% of the time, the caps WILL fix them though...) A good shop should be able to rebulid your module for about 300-400 in the home.
Oct 10, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi tv model ws-65315, when i turn the set on, the green light comes on for a second then the set turns off what could it be
Check the voltages at the test points on the power supply. If the voltages are correct and all the fuses are fine, check for swolen capacitors on the format and the DM boards and replace them
May 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
I have a mitsubishi 48" integrated 1080. The Timer green light keeps blinking. I have no picture. Can this be the fuse? My coworkers say this might be the problem. Can I replace it myself? If so, where is it located?
meeh.shell@yahoo.com
Oct 13, 2008 | Mitsubishi WS-55809 55" Rear Projection...
DM board
They have the repair kits for the mitsubishi DM boards at the following link, which contains the replacement capacitors and the CD with step by step instructions.
http://servicemanuals.vstore.ca/
Oct 13, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Will not turn on completly
if it is like mine- it's the power board. It is no longer available so you have to buy a new TV
Dec 02, 2007 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
578 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
