Question about Frigidaire Freezers
I do not have a manual so I don't know how to defrost it
How do I defrost the upright freezer I cannot find any pan under it
  • 1,543 Answers
Look for a white plastic plug in the floor of the freezer, about the size of a quarter. Remove that. Take the front grill off and feel underneath for a plastic hose (one end connects to the drain hole, the other end you can catch defrost water in using a shallow pan). Use a hair dryer to melt the frost (with the freezer unpluged)
Posted on May 31, 2009
Does the upright freezer model# 29701000D have a drip pan?
if it is a manual defrost freezer it will not have a drain pan. if it is a frost free freezer then it will have a drain pan
Jul 27, 2014 | Freezers
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My frost free freezer has had a small puddle of water under the front right corner several times now. I unplugged it and let it defrost completely thinking that would stop the problem but it hasn't. Can...
There is a chance the water is coming from the drip tray and or the drain hose to the tray.
when the unit goes into a defrost cycle it is leaking from one of those places check and make sure the hose is in the drip pan correctly and that the pan is also mounted properly and level.
If there is is a lot of water in the pan you may need to check the door seals on you unit and make sure they are sealing properly.
If there is an air leak then the unit could have excessive ice build up and also be defrosting more than usual amounts of water.
Jan 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Did Woods V161RW3 Upright Freezer - Manual defrost have a drip pan?
CALL Chas&Son,s at 570-379-0993 and they will come out the same day no less okay
Nov 27, 2010 | Woods Upright Freezer V1613RW3
Amana upright freezer leaks water on floor instead of in drip pan under it.
check the flor of the freezer if it is caked with ice your defrost drain is clogged
if not
take off the back panal
under the machine follow the drain tube
to the drain pan clean out your duck bill and make sure the tube is in the pan
Oct 06, 2009 | Amana 16.7 cu. ft. / 473 liter Upright...
Manual defrost
On my upright freezer I use pans or trays I have and set them in the bottom where it catches nearly all the water. I don't have to empty them till it's all melted because it till hold all of it.
Sep 06, 2009 | Fisher Scientific Freezer Isotemp* Plus...
How do I defrost my upright freezer ? no pan found under it
Hi, All you have to do is UNPLUG the freezer and leave it of for a day or use a hair dryer to defrost it quicker.
You will get water so use a few towels to catch it.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Freezers
Freezer bad smell
the defrost pan is located under the frig. if there is a cover at the bottom on the front remove it and the pan should slide out
Nov 17, 2008 | Frigidaire Freezer Refrigeration White...
G.E. 20.3 CU FT UPRIGHT FREEZER
Check condenser fan to see if it's working. It's the fan next to compressor
Nov 20, 2017 | GE 20.3 cu. ft. / 575 liter Upright...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
155 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
