Question about Frigidaire 19.53 cu. ft. Commercial Freezer FCFS201LF Stainless Steel
Continuously running freezer
Hi, I have noticed that our freezer (in the garage)has been running every time I go out into the garage for the past two days. I did put a lot of meat in there yesterday, but it was frozen, not thawed. The weather has been mild. I stuck our thermometer in there, and it is -2 degrees F today, and it's still running. I tried to find the temp control, but I don't remember where it is inside the freezer. I am hoping I don't have to empty the darned thing. Thanks! Karen
    President:
  • 1,136 Answers
Hi, The picture I get shows the temp control in the uppr left hand corner. It should be set to half of whatever is on the dial.
I had about eight different possiblities on model #. Could I get the whole # and look this up again?
Posted on May 31, 2009
Is the Kenmore Freezer model 23971 supposed to run continuously or should it be alternating on and off? Mine is running all the time and I am not sure if this is broken or working correctly.
If it is in a warm garage or the sun is shining on it through the window its going to run a lot. Try putting a thermometer inside and see what temperature is. Leave it in for an hour or so. It shouldn't be below 0 degrees F unless you have some high quality ice cream in there that needs a colder temperature. Slowly turn the temperature up one number increment every couple of days until you reach 0. Hope this helps and good luck.
Oct 05, 2014 | Freezers
Greetings: I have a 4-5 yr old Whirlpool up-right
lucky to get five years out of any white good
time to do the math
replacement cost of failed components
verses
benefits of a new up-right Freezer
Feb 28, 2017 | Whirlpool Freezers
Freezer runs continuously
not necessarily. If it's the t'stat, the unit would continue to drop in temp. If temp does not drop, it may be a dirty condenser coil or other issues. Don't just swap parts, check things out. use thermometer and check temp several times over a long period of time. If t'stat is bad, temp will drop continually as unit will not shut off.
Hope this helps.
May 17, 2010 | Freezers
Motor runs continuously
The motor is getting very hot because of running all the time and not cooling properly...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 10, 2010 | Frigidaire Freezers
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
My Kenmore freezer is continuously running. It
clean all of the door seals and all of the contact point with freezer
Jul 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Fan continuously running, non-stop
hi thanks for the question its normal for a frost free freezer to run a long time to keep a good cold temp i don't think you have a problem thanks the appliance doc
Sep 08, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Running continuously
Hello bxrjer,
Welcome,
You said, you have a FFU20FC6AW2 freezer that I have noticed is running continuously. Explains my $400 electric bill.
How old is the freezer?
The thermostat may be faulty.
But check out this list first.
If the black tubes running back and forth that carry the freon is under the freezer and behind the plastic grill down near the floor you may want to remove the grill cover and gently run a refrigerator brush across the coils. Ive seen them never cleaned and full of lint and dust 2 inches thick.
This is not good for the freezer or any refrigerator too!
They need to be clean so air can run across them or they over heat and get hot.
Room or outside weather is hot. It is normal for the freezer to work harder under these
conditions.
Reasons why Freezer may run too much or too long.
1.Freezer had recently been disconnected for a period of time. Freezer requires 4 hours to cool
down completely.
2.Large amounts of warm or hot food have been stored recently. Warm food will cause the
freezer to run more until the desired temperature is reached.
3.Door is kept open too long or too frequently. Warm air enters the freezer every time the door
is opened. Open the door less often.
4.Freezer door may be slightly open. (Freezer is not level. It rocks on the floor when it is moved slightly. This condition can force the cabinet out of square and misaligned the door.Freezer needs to be leveled if this occurs.
Floor is uneven or weak. Freezer rocks on the floor when it is moved slightly. Level the floor by using metal or wood shims under the freezer or brace floor supporting the freezer.
5.Temperature control is set too cold. Turn the control knob to a warmer setting. Allow several
hours for the temperature to stabilize.
6.Freezer gasket is dirty, worn, cracked, or poorly fitted. Clean or change gasket. Leaks in the
door seal will cause freezer to run longer in order to maintain desired temperature.
Let me know what you find
Huuum
Please remember to leave a rating before you leave.
Aug 18, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Frigidaire 19.53 cu. ft. Commercial Freezer FCFS201LF Stainless Steel Logo
136 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
