Question about Hayward Pool Products Hayward H-Series Above-Ground Heater
Pool heater starting
Problems lighting the heater after sitting all summer
  • 640 Answers
Here is a copy of the users manual for these pool heaters. There is a lot that could need to be adjusted or fixed if it is just not coming on at all. Try the troubleshooting guide.
http://www.backyardcitypools.com/images/Hayward/H100-Manual.pdf
Posted on Dec 07, 2010
    Problem Solver:
  • 9 Answers
What type of heater is this, millivolt or electronic, is there a standing pilot if so will pilot stay lit, if pilot does not light you may have an obstruction in it which needs to be cleaned.
as well as checking gas orifices for blockage
Posted on Jun 18, 2009
What does this code mean? :LO
check pressure switch or copper tube to it
May 22, 2014 | Raypak RP2100 DIGITAL POOL HEATER R265
Electric Pool Heater Tripping Out!
What is the model number of the unit?
Jul 13, 2013 | Water Heaters
Pentair megatherm pool heater problems
check gas pressure sounds like overheated
Jan 09, 2013 | Pentair Commercial Mega Therm
My jandy lite2 heater is doing nothing when turned on to heat pool or spa, finishing up my 3rd summer with it and this is my 1st problem.
check to see if 24 volts ac to the pressure switch if not check copper tube for clog if ok see if ignitor fuses blown if so replace if they blow again check ignitor probably bad igintor
Aug 20, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
My heater started with no problem the first time earlier this summer. Since then I have not needed to use it, but tried to start it again this week. Pilot light is on, but when I turn the switch on there...
If you have a by-pass valve be sure it is closed or almost closed. Also check your baskets and clean your filter. All of these will give the heater low pressure and keep it from running.
Aug 10, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
So we have the jandy laars lx.... we have had it for 3 years no problems we use it with pool and spa and its gas........ the buttons work you can choose pool or spa just fine but when you choose one... the...
This heater wont start if the pressure switch is bad or clogged. Remove the pressure switch and clean it out really well, or just purchase a new one. It should only be $30-$50 depending on where you go to get it
May 03, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
It wont start
If you nothing is coming through and you have a full cylinder first check the regulator is working OK, just take the hose off and turn the cylinder on for 2 seconds (do not light it). Next check the fuel pipe is clear, if OK check for a leak, to do a leakage test see patio heater problem solving page. If that is OK check you have a spark and the lead is not shorting out. If the pilots lights but goes out then try changing the thermocouple.
Jan 20, 2011 | Endless Summer Blue Rhino 235000...
Heater c0mes on but turns off after a minute, sometimes longer. Light flashes flameturn off switch, let sit and will run alittle longer.
Remove the top cover, check for infestation of stinkbugs while sitting idle over the summer. Remove them and that may solve your problem. It worked for me!
Jan 01, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Hayward Pool Products Hayward H-Series Above-Ground Heater Logo
316 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
