Question about Frigidaire FRS23R4A Side by Side Refrigerator
Will run all the time
Runs  all the time up right  frigidaire  ffu20fc4awo
  • showfiend Feb 08, 2008
    frig. runs all the time. Ive cleaned coils. Unpluged unit. waited about 5 min. still runs. freezer is not very cold .some food is thawing like Ice cream,popcicles,sauces.Nothing is blocking air vents.There is no icemaker. My E-Mail is babbles11@sbcglobal.net My refrig is about 10yrs. old
  • Frigidaire Master
  • 4,655 Answers
Could you tell me more info like, how is the cooling and freezer temps. Is food spoiling ? does the defrost timer put it in defrost?
Posted on Oct 23, 2007
  • John Tripp
    John Tripp Jul 02, 2009
    I am curious as to know if my solution helped you. Please explain what was needed to repair the fridge. Thermostat, defrost timer or other, Thanks, Sea Breeze
No it doesn't go into defrost. freezer temps are bad about30 degrees
Posted on Feb 08, 2008
Frigidaire Dishwasher has error code i30 and drain pump still runs even with door open. Tried power cycle and comes right back on running and error code i30.
Error Problem / Condition = Clogged filters or a restricted drain line has been detected. ... If the drain line is attached to a disposer, check that the knockout plug has been removed. Frigidaire Dishwasher Error Code = i30. Error Problem / Condition = A leak or over flow of water has been detected in the bottom pan.Feb 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-how-t...
Text info here
Frigidaire Dishwasher has error code i30 Google Search
Jun 09, 2018 | Frigidaire Dishwashers
I have a frigidaire FRFW model washer that keeps beeping when it's plugged in. All the lights along the right side blink 9 times and then pause then 9 times then pause. Washer won't run.
I just had the same E90 code with my "good model" Frigidaire washer. It beeps 9 times, then pauses and repeats. Nothing worked as far as resetting, unplugging,etc. HOWEVER, I saw this guy's video and his "hairdryer technique" worked perfectly.
https://youtu.be/IhHvw2K7XO0
I took it a step further by not only removing the two screws from the back of washer and the top cover, but also removing the front panel w/buttons by taking off two scews in front top corners and three scews inside the detergent drawer (take drawer out first). I moved the hairdryer back and forth over all the wire harnesses for about a minute, plugged it back in and it beeped once like normal. Put it all back together and it's running a load of wash now!! Good luck.
May 23, 2018 | Frigidaire Washing Machines
Frigidaire dryer dryer will not run starts for 5sec then stops
frigidaire dryers have alot of problems with the control board,if it starts then fuses are good or it wouldn't run,does it start right up again?if so you have a bad board,if it doesn't start right up again the motor most likely is bad,any error codes?you could have a bad or broken wire somewhere in the dryer but like i said,they have alot of board issues,next time send the model number,if you know where the board is open up the dryer,unplug it first,then when you find the board plug the dryer back in and start it,when it stalls try tapping on the board,it might start again,if not unplug the dryer and look at the board to see if there's any burn marks on it or a bad soldier joint,also it might have a burnt smell to it.
Dec 31, 2017 | Frigidaire Dryers
Accidentally unplugged my upright frigidaire temp light on and not freezing
If compressor is running, have you given it enough time to recover? or you may have a faulty thermal protector on the compressor. Cold control setting on right position?
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Dec 23, 2017 | Frigidaire Freezers
Frigidaire FEQ1442CESO wont stop beeping
Mine did the same thing. It started right after the warranty ran out. I dealt with it for a long time until 1 day it wouldn't stop running. I saw a couple internet posts about defective circuit boards in this model so I got brave and took mine apart. Once I got the board out and examined it I found 7 or 8 cracked solder joints, including the main power supply to the board. I reheated them with a soldering iron and added a little bit more solder to a couple of them and now my dryer works like the day it was new.
Jun 14, 2014 | Frigidaire FEQ1442ES Electric Dryer
We have a new Frigidaire FASG7074NR2. It stopped at the beginning of the cycle and read door open. The door was not open. We tried opening and firmly closing the door and unplugging but it still reads door...
Short answer - $5 door switch. I've dealt with this at least 3 times in the last 5 years on Frigidaire, Electrolux & Whirlpool dryers. I certainly hope it's the right fix action for you as well. Cheers.
Jun 14, 2014 | Frigidaire Fasg7074Lr 7.0 Cu Ft Gas Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2012 | Frigidaire Dryers
Don't know how to set clock on frigidaire range model # RG94BF*0 please help
There are 3 knobs below time display and one to the right.
Push the right 2 buttons at the same time while turning the right knob to set time..
Apr 06, 2011 | Frigidaire Ovens
UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Jun 28, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
177 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
