Question about JVC PD-42DX6 42 in. Plasma Television
JVC 42" Plasma TV Green vertical lines....GD-V500PZU
I am just wondering for how much and where I can get a Y-Sustain PC Board for  JVC 42" Plasma TV Model number GD-V500PZU.
Any help would be greatly appreciated.
SOURCE: HDTV 42 inch Plasma Sanyo model DP 42746
the picture is very dark
Posted on Jan 24, 2008
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Posted on Jul 26, 2008
SOURCE: GD-V425PZW powering off
Hi Boris,
I cleaned out the fans on top of the unit - all seemed OK
basically overheating i think
Posted on Aug 20, 2008
SOURCE: HP 42" Plasma
I do not have a manual, but HP just replaced my Y Sustain board on my PL4260N (Model (ED429AA).
HP replaced it free because of a known problem with something they call "Plasma Mal-Discharge'.
The part number on the work order is 1032298-HS.
This did not fix my pixilation lines across the top.
I have been told that my Y-DRV is probably bad, but I need to pay for that replacement.
But, they did not verify that it is bad and did not guarantee this is what is wrong.
Posted on Oct 16, 2008
SOURCE: Y Sustain Board Replacement
I found the Z Sustain / Y Sustain (P/N: 6870QYC004A 6870QYC004B 6870QYC004C 6871QYH039A 6871QYH039B 6871QYH039C) here for CHEAP:
http://www.discount-merchant.com/Y-SUSTAIN-PN-6870QYC004A-6870QYC004B-6870QYC004C-p/vizio-sku9501.htm
I found the X Sustain (P/N: 6870QZC004A, 6871QZH044A, 6870QZC004B, 6871QZH044B, 6870QZC004C, 6871QZH044C, 6870QZC104A, 6870QZC104B, 6870QZC104C) here: http://www.discount-merchant.com/We-provide-factory-original-parts-worldwide-p/vizio-sku9502.htm
These are also compatible with the following brands according to Discount-Merchant:
ZENITH, HP, VIZIO, MAXENT, LG, ZENITH, SONY, HITACHI
Posted on Jan 14, 2009
I have an LG 42PJ350 plasma TV which has suddenly developed a vertical green line around 1.5in wide from top to the bottom of the screen. It makes no difference whether watcing TV or using XBox. Is this...
Yes, life span on Plasma and LCD sets is 3-5 years.
The green line (or any line) can be a board (sustain types on Plasma or inverter on LCD) but can even be a control problem inside the set--area that controls scanning etc) and in worst case can be the display panel itself--fatal issue.
Trouble shooting entails a signal generator, a expensive scope, and a good set of hands working with them to check voltage, waveforms, etc to try to decide where the problem is.
Then we have the board jockeys who guess and try one board after another (gets expensive and takes time) to see which if any board will fix the problem---when all boards have been tried (seen this ) all that is left is the panel or display unit--cost for that is more than the set new.
Apr 12, 2012 | LG 42PJ350 42 in. TV
JVC PD-35D30ES Vertical lines - problem
Hello
Check its power supply board for any damaged capacitors. Replace them if found or suspected. Take special care to main filter capacitors. check all the output voltage smoothing capaciotrs too.
If all are OK, and still the problem perists, replace the power supply board as card basis.
Feb 07, 2012 | JVC PD-42WV74 42 in. Plasma EDTV
Hi i have a JVC GD-V4210 PCE it has power but it has no picture or the fans has no power the led goes green when turned on then goes flashing red please could someone help
Your TV power supply board is damage and will soon cause your TV to not power on. Yes, cleaning the fan will only temporary fix the situation but eventually you will need to fix the power supply board. You can order one on ebay or amazon but make sure to have the correct serial/model number on the back of the TV before ordering and fixing it yourself. However, if you are not sure then have a certified tech to come see it.
Sep 01, 2010 | JVC GD-V4211PCE 42 in. Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Jvc gd-421pce stuckinstandby
Hi there, did you ever solve your problem as i have the same problem?
Oct 08, 2007 | JVC GD-V4211PCE 42 in. Plasma Television
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
JVC PD-42DX6 42 in. Plasma Television Logo
175 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
