Question about Philips 50P8341 50" Rear Projection Television
Green color has taken over tv
Philips big screen tv green color has taken over tv
OK IF THE COLOR GREEN HAS "TAKEN OVER YOUR TV" AND YOU USE A CABLE BOX, ITS PROBABLY THE CABLE BOX. I HAD THE SAME PROBLEM. YOU JUST NEED TO EITHER HIRE SOMEONE TO COME TAKE A LOOK AT THE TV AND/OR CABLE BOX, OR BUY A NEW CABLE BOX AND/OR TV! SIMPLE,HUH?
Posted on May 31, 2009
There are greenish images everywhere in my Philips Led Tv. There are 2 big and old Technics loudspeakers near it.
your ty is working well.
try to wach something other, and if there are still green parts of the screen, try to change the color settings of the tv
Apr 13, 2013 | Televison & Video
My Philips magnavox 64 inch big screen tv has a green tint to it and i cant adjust with any of the color or tint options..
have the glycol ethelyne changed in your color guns, couple hundred bucks. i tried it myself and ruined my tv
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
Magnavox big screen has dull picture and colors are not clear. Cloudy picture and has a green film of color over screen. this ia a 64inch big screen. What can
This is especially common with Phillips/Magnavox - A foggy image usually suggests that the coolant in the picture tube(s) (1or all 3) has become discolored and needs to be replaced. The only way to check this is to look directly into the crt faces (disassembly required) to see the condition of the fluid (coolant).
It's a relatively big job that shops charge between $300-400 - Get an estimate. See link for Kit
http://www.tvrepairworld.com/crt_coolant
Nov 06, 2009 | Philips Magnavox 27MS343S 27" TV
Color serperation of red and green
The convergence output IC's have failed which is a common problem with all projection tv's. They need to be replaced and this is somewhat of a major job. Unless you are real handy those big amps are not easy to get to or desolder and replace. A reputable tv repair shop usually charges around $200 to $350 to do the job.
May 27, 2009 | Philips Magnavox 9P6034C 60" Rear...
Bad color suddenly appeared on Maganavox 437S 52 " Flat Screen HD
it should have a year warranty get it in for warranty repair before the warranty runs out or someone tells you the wrong thing to go and the tv ends up as a big paperweight...
Dec 28, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Screen color problem
the colour problem is most likely because of signal interferance from things like microwaves and believe it or not, the sun. or it may be caused by partially dead pixels. another thing that may cause a problem like this is dust in the screen. have it taken apart and cleaned by an experienced/liscenced person. if you are nither, don't try it. you may damage your tv, or worse, hurt yourself.
May 22, 2008 | Philips 9P5034C 50" Rear Projection...
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
Philips Flat Screen Green Lines
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
Nov 28, 2007 | Philips 20 in. TV/VCR/DVD Combo Flat...
Color on my big screen tv
sounds like you need to have the two convergence IC's replaced. These are soldered on the main board. Good Luck
Jul 16, 2007 | Philips 46PP9302 46" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
272 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
