Question about Soundstream VDVD-150 Car DVD Player
Set up code - Dolphin II - Balboa remote control
I would like to get the set up code of Soundstream VDVD-150 Car DVD Player in order to program my Balboa remote control..Dolphin II
2 Suggested Answers
  • 93 Answers
SOURCE: lost audio/video remote for a soundstream VIR 8004
Here is a universial one im not sure if its what your looking for or not.
Posted on Apr 27, 2010
  • 3018 Answers
SOURCE: The fuse in the yellow
  • First thing is that if that fuse blew then check for any other fuses that might have blown too. I don't know if this head unit is hooked up to the battery or into the dash or through a harness. You may want to check the fuse under the dash if using a harness wired into the vehicle itself. If it is hooked up to the battery then check the power wire right off the battery for a fuse. There is no fuse in the head unit itself. Just inline fuses.
  • Try pressing the reset button on the head unit too. The reset button is a little hole on the left side of the LCD. Stick a paperclip or any non sharp but tipped item and hold for 8 seconds.
  • You can also try to disconnect both battery cables and wait for two minutes and then hold them together for another minute and then hook the cables back up on the battery and see if this resets the head unit.
  • For a stuck disk in general you can take a credit card and wedge it under the disk a bit and try to pop the disk out and at the same time pressing the eject button.
  • You want to remember that if the surge blew the fuse it is entirely possible that some reached the head unit and messed the radio up internally.
  • If you have any comments please feel free to leave them here and I will respond.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 15, 2011
0 characters
1 Points
Remote control
If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Feb 26, 2014 | Nesa Vision Car Video Players
What cable do you need to use an ipod
depends on the the type of aux input. if the reciever has a usb port use the standard ipod charge cable, however if it has something that looks like a head phone input you will have to buy a male-male auxilary cord from an audio or hardware store.
Jun 21, 2010 | Soundstream VDVD-300R Car Video Player
What do i do when my soundstream vir-6500 screen went blank
Send it in for repairs. It has likely had the ribbon cable damaged.
Thanks for using FixYa - a 4 TUHMBS rating is appreciated for answering your FREE question.
Nov 04, 2009 | Soundstream VDVD-160 Car DVD Player
Car dvd players
sory I did not see that this system will play external vieod, it looks like soumd only not video.
her is a list of specs you ca see for your self.
hope this helps you.
N-CITY DVD-393 In-Dash Car
DVD/VCD/CD/CDRW/MP3/WMA/MP4 Player with Digital
Slot for USB/MMC/SD Memory playback
The New DVD 300 series from N-CITY comes with
everything you expect
Fully featured with Digital Media Slot for
DIVX Playback, Sub-Woofer output & smart resume function
��. Support USB & MMC/SD Memory Card for direct playback
��.Big size Dot matrix Display
��.DVD/DVD-R+/DIVX/VCD/MP3/ WMA/MP4/CD-RW Compatible
��.Fold Down Detacheble Front Panel
��.MP3 Selection by Sequence Number & Track Name, ID Display
��.Encoder Volume Control
��.Super Electronic Anti-Shock
��.Preset EQ (Flat/Pop/Rock/Classic)
��.AM/FM/MPX PLL Tuning Stereo Receiver
��.30 Memories System (FM18/AM12)
��.Auto Memory Store
��.Repeat/Program/Random/Intro Play
��.Electronic Audio Control
��.8-Times Oversampling
��.Mute / Loud Control / Clock
��.Auto Loading and Ejecting
��. 1- Bit D/A Converter
��. RCA Preamp Output
��. Subwoofer Output
��.ISO Mouting Chasis
��. 4 Channels Output (2V Preout)
��.60W X 4 Power Output
��.Full Function Remote Control
Jan 13, 2009 | Soundstream VDVD-300 DVD/CD/MP3 Player +...
No audio
you may have a factory amp
Apr 28, 2008 | Soundstream VDVD-300 DVD/CD/MP3 Player +...
Soundstream VDVD-150 Car DVD Player Logo
189 people viewed this question
Top Soundstream Car Video Players Experts
Matthew Spark
Matthew Spark
Joseph Gallucci
Are you a Soundstream Car Video Player Expert? Answer questions, earn points and help others
