EFUN NextBook NEXT8P12 8" Tablet Logo
k
khaji lewis Posted on Jan 20, 2014
Screen wont turn back upright - EFUN NextBook NEXT8P12 8" Tablet
Roger Allerton
Level 1:
  • Contributor 88 Answers
  • Posted on Jan 21, 2014
Roger Allerton
Contributor
Level 1:
Answers
88
Questions
0
Helped
13165
Points
99
Swipe down from the top. A band of icons appears. Look for the rectangle (top left I think) This is the Screen Lock Icon. Tap it to turn screen Lock OFF. (Or on the EFun it may be a Wheel icon for screen lock.)
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
Xelio 4gb wont turn on
Had same problem, turned out to be fault in firmware operating system, replacement tablet.
I wa downloading some games, wanted to go back to the main screen and now it is frozen on "Tablet pc screen" it wont turn off or do anything
Press and hold the power button for about 20 seconds. You should see some flashing. Let go of the button and watch. It should reset it's memory and come back on. If this does not work then call your tablet's customer service.
Screen Reset
Check to see if it is in the " Sleep " mode.
It wont turn on
If it just hangs at the loading screen (doesn't turn itself back off automatically), you might need to do a factory reset on it. How you do that varies between each model of tablet.
My kindle fire pg is sideways and will not turn upright..what do Indo?
You have asked about the Kindle eReader, but your question refers to a Kindle FIRE.
On the eReader touch the Aa button and select the correct orientation that you require.
On the FIRE drag down from the top to reveal the top MENU - select the CIRCLE icon on the left which is the SCREEN LOCK icon. Turn it off.
My Freelander PD90 tablet wont turn on
Hold down the power button for about 20 seconds, this should hard reset the phone/tablet.
Top EFUN Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an EFUN Tablet and eReader Expert? Answer questions, earn points and help others
