Question about Microsoft Xbox 360 Console
Unreadable text My Xbox 360 is connected to a normal (non HD) TV and the text in the games is fuzzy, making it very hard to read.  I have tried formating the "display" in the system settings.  I chose the "Normal TV" option but I haven't had any luck.  Do you have a solution?
  • 48 Answers
I do not believe there is a solution. I had the same setup and could not read the text. I tried everything and eventually got rid of the 360 because without an HD TV, I could not read anything.
Posted on May 31, 2009
Hi everyone, Im new to this thread, but I have very high IT experience. However, I have a problem that I just cant figure out. My Dynex tv randomly started acting up. All my colors and channels are...
check the connection to your tcon board and main av board. if the connections are good one of these boards is more than likely bad. Google their part numbers and see if that board has a known issue
thanks,
michael
Apr 05, 2011 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
How do I fix a fuzzy screen
A fuzzy television screen is generally not the fault of the game console itself, but of your television.
The Xbox 360 is an HD game console, and from personal experience, trying to render an hd image in 480i Standard Definition will cause it to look somewhat fuzzy regardless of the television.
Just to make sure it is not the Xbox, I would, if possible, suggest you try the 360 on another television, preferrably with the HD cables (remember that there's a switch on the cable itself that you will need to switch from SD to HD).
Unfortunately, if you do not have access to a high def television, you can always fiddle with the contrast and sharpness on your standard def TV to reduce the fuzzyness, but the screen will always be somewhat fuzzy.
I realize this is probably not the answer you wanted, but to solve this problem for my own Xbox, I ended up purchasing an inexpensive HD Television.
Nov 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 only reads some games and says others are unreadable.
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
You can use the recommended guide to fix this and get back to gaming.
Feb 21, 2010 | Microsoft Xbox 360 Console
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
Xbox says disc is unreadable
Try And clean it breath on itand wipe with your tshirt
Feb 28, 2009 | Microsoft Xbox 360 Console
There are fuzzy lines on the screen when i play any of my games
you could try checking the AV cords that connect your TV to you xbox 360 and making sure they are securely connected
Jan 28, 2009 | Microsoft Xbox 360 Console
When x box 360 is plugged in to tv,there is no signal
try reconnecting all the cables and make sure you have the right setting(normal tv or hd, theres a switch on the cable), if that doesnt work, you might have a faulty cable, or even worse your xbox has an interal problem(very hard to explain, read this if you cant connect to tv....(http://xbox-experts.com/e/errorcodes.php) and you'll need to send it to microsoft for repairs.
Nov 12, 2008 | Microsoft Xbox 360 Console
How do I connect xbox 360 and Wii to TV on HD ready service?
Actually this service didn't help me. I have been fobbed of with an answer. After trying a couple of things that I actually read before hand out of a text book, your Expert!! advised me that infact I do not need to use the HD button supplied on my Xbox as my TV is HD ready...... Even the TV experts laughed at that.
Jul 03, 2008 | Hitachi Televison & Video
Fuzzy picture
You can't make SD look like HD thats why HD came out, the best you can do is adjust the picture controls to get the optium picture
Apr 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Microsoft Xbox 360 Console Logo
121 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
