Question about KitchenAid KESC307 Electric Kitchen Range
The Oven light wont turn off!
My KitchenAid Range, has a problem. The oven light won't turn off.
  • Samuel Charles Spriggs May 11, 2010
    Do you see a switch (or a hole) anywhere around the edge of the oven when you open the door?
    Problem Solver:
  • 7 Answers
The button that depresses when the oven door is closed is probably stuck in the (IN) POSITION. spray some WD 40 on the switch if you can find it. It should be somewhere around the door jam..
Posted on May 31, 2009
5 Suggested Answers
  • 57 Answers
SOURCE: Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
Posted on Sep 22, 2009
SOURCE: Garland H283 gas range. Right oven wont come on.
I just read this here:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=13&newsdesk_id=117
that explained how to test if the problem is the thermostat. It said to watch the pilot as you open the thermostat to turn on the oven. If the thermostat is ok the pilot should get bigger, if the pilot does not change when turning on the thermostat, then the thermostat is bad.
Posted on Mar 30, 2009
tony2155
  • 64 Answers
SOURCE: range has error of stuck key
need to replace touch pad not cheat
Posted on Jun 23, 2009
SOURCE: kitchenaid gas range model KGRS807S - oven starts then stops
earl am16 error
Posted on Apr 16, 2010
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Error code f3e0, oven wont turn on, follow instructions to set temp, after hitting start, get 3 beeps.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Oct 03, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
Oven wont turn on.
Ours did that and I installed a new igniter. Took the old one out and went to a store that sells them. Installed it myself.
Sep 29, 2017 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
1,333 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
