Question about Marantz SR-4200 Receiver
DV4200 DVD Remote Control Funtion Failure
I have a brilliant Marantz DV4200 DVD player which has recently developed a very inconvenient problem whereby the remote functions no longer operate. The remote control handset has been tested & is fully functioning, however a local techncian has indicated that the remote chip in the set box is faulty and requires replacement. The big problem is that those parts are apparently no longer available in Melbourne. Having no remote functionality is grossly annoying particulartly given that not all funtions are accessible via the DVD set box butons. Rather than having to replace / upgrade this factastic DVD player, any assistance with providing access to a spare chip would be sincerley appreciated. Thanks Evan
    Top Expert:
  • Marantz Master
  • 23,200 Answers
If the 5volt supply is not missing, due to a dry joint on the front panel, check for data on pin 2 of the IR receiver. The receiver module is a common part to most Philips machines. The main micro is not likely to be at fault.
Posted on Mar 27, 2017
hokuwho
  • 306 Answers
SOURCE: buzz in amplifier power transformer.
All transformers buzz though you cannot hear it normally. The big transformers on power lines like to buzz for all to hear. When a transformer in a stereo amp gets old and deteriorates or gets hot and  expands the coils, melts the coil varnish and epoxy coatings then rattles at 60 times per second.    You can ignore it or change the transformer. There are too many layers of windings to try to stick anything in there.  Disconnecting a transformer results in inductive kickback -that's not money. It's a big, whopping electrical gotcha! Be careful! Good luck, Steve Medley
Posted on Nov 09, 2008
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
  • 5 Answers
SOURCE: marantz sr4200
I use a Logitec Harmony 520 programmable remote. I pay 80$canadian.
http://www.logitech.com/index.cfm/440/371&cl=ca,en&hub=1?selectedcrid=440&selectedcid=371
Posted on Mar 08, 2009
SOURCE: Marantz SR-18ex remote control number
If you mean the model number, that is: RC-18SR
Posted on May 15, 2009
  • 8 Answers
SOURCE: Do you know the remote
The stock remote for the SR-18EX is the RC-18SR - that's the one it shipped with when new. You can also use the RC-2000, RC2000 MkII, and I have an aftermarket RC-1400 that works perfectly with my SR-18EX, AND offers 15 macros instead of the standard 4 you get with the stock remote.
Posted on Oct 18, 2009
Marantz remote controller rc001dv permantley on
It's probably defective. Send it back to be replaced..
Sep 02, 2012 | Marantz RC001DV Remote Control for DV6001...
Lost remote control
Go to www.ebay.com Type: make and model of player, refine search to hand remote, if no luck! try www.marantz.com contact customer support and the technical department.
May 09, 2012 | Marantz CC4001 Five Disc CD Carousel...
The remote does not work
Hello my Marantz dv4100, didnt respond to my remotecontroll, Remote was working. remote from my philips dvd722 works fine with this Marantz-dvd too.
i found 2 solderings at the back of the front circuitboard in remotecontroll receiver optounit at the left side of dvd-display, pins 1 & 2 needed resoldering, had cracks in solderings. after that it was working fine again.
hope this helps u too.. good luck!
Dec 23, 2010 | Marantz DV4100P DVD Player
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
Dog ate my sr3000 remote
get a logitech harmony, very easy to setup using computer.
Feb 28, 2009 | Marantz SR-3000
Bought dvd/vcr dual player with no remote in box
You should contact a service center and they should send you a remote control if you are in the 90day warranty.
http://www.funai-corp.com/support/contact.aspx
Otherwise you could try a universal remote available anywhere.
Feb 03, 2009 | Philips Magnavox DVD/VCR Dual Player
MARANTZ : Connection problem ZR6001server/ZC4001client, remote control influence ?
Hi!
Perhaps the distance between the two energy plugs (ZR6001 & ZC4001) is to big. Also it could be, that other systems plugged in the energy supply of your home are disturbing the signal.
I've no really connectio0n problems. Length is about 20m of energy supply line.
But I've problems with controlling DVD Player of marantz, directly connected to the ZR6001 (REMOTE IN/OUT correct connected) by ZC4001. There is no chance to start DVD Player which is in standby, also no chance to control playing with PLAY, STOP, PAUSE, NEXT, LAST etc.
Perhaps you could help me with my problem?
THX
Oct 15, 2008 | Marantz ZC4001 Expansion Audio Player For...
Bush DVD 2038 DVD player
I contacted Bush custimer care and this is the reply I got:
We apologize for the inconvenience caused to you.
We would request you to kindly reset the remote control by following the steps mentioned below:
1. Remove the batteries and reinsert the batteries after 1 minute.
2. Press and hold the top, right and the bottom navigation button on the
remote control along with the number 1 button (as in 123) for 10sec.
It didn't work for me, but I have posted it on here, just in case it works from someone else
Feb 02, 2008 | Televison & Video
Sanyo dvd player
Here is your manual
http://www.ofausa.com/remote_manual/URC4110%20manual%20booklet.QXD.pdf
Here are your codes
http://www.ofausa.com/list_codes.php?db_value=access4&remote_choice=URC4110
If the code is not on the list try the code search funtion. If this does not work your remote may not support this unit.
Nov 04, 2007 | One For All URC4110 Remote Control
Marantz SR-4200 Receiver Logo
70 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
