Question about HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Start Up Problem
I cannot switch the printer on. When i connect the power the printer does a self test OK. Then when I press the on off sitch nothing happens. Is this terminal? Any suggestions?
  • 734 Answers
Re: HP PSC 2210 All-In-One InkJet Printer Start Up...
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
0 characters
3 Points
May be no ink; how can I check the cartridge have ink or not? and how can I change the cartridges?
Test cartridges first.
Press 1
press 5
this selects - self test
press start black or start color
this link will take you to hp and a pdf version of the owners manual.
Feb 26, 2011 | HP PSC 2210 All-In-One InkJet Printer
HP 2210 all-in-one printer won't start.
I request you to check the power cable of the printer and remove the ink cartridges from the printer and power off the printer.
Wait for 2 to 3 minutes and then power on the printer. If still does not work check with different power outlet.
This should work.
Jan 17, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP Psc 2210 powers up for around 5 secs then switches off
Unplug both ends of the power cord and count for about 60 seconds. Then plug back in. See if that works. That's what HP told me when I called customer service.
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dead PSC 2210 - can't get print cartridges out!
Try connecting the printer directly to wall instead of surge protector and see if tha resolve the issue
Aug 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Self test flashes for a few seconds comes when power is connected and then power is lost
check us power cable that is ok? and also check ur usb cable which is connected with the pc. if power cable is ok then i think its ur hp power button fault. then repair ur power button. then it become ok
Aug 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
Can't find power cord location on back of hp psc 2210 all in one
Warning, PDF.
Jun 29, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 2210 scanner self test problems
If the glass of your scanner is too close to the scanner array it can jam. The cure for this problem is to open the case and put some narrow strips paper under the glass. If under Guarantee take it back.
Doubt if you can bypass the self test.
Mar 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Self-test issue with HP psc 2210 all-in-one
No fix, a new scanner will cost as much as a new machine IF you could find a new scanner assy
Feb 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Can't turn my PSC 2210 on
i have to start with the merely obvious first. plug something else into that outlet and see if it works.
Aug 29, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
59 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
