The player stops and opens the drawer by itself when a disc is placed in the player to run and play
SOURCE: Pioneer CLD 990 Player
The "no disc" message will show up any time the unit tries to play a disc and fails. This can be because the lens is dirty or the optics have failed. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are failing and will need to be replaced.
Dan
SOURCE: I have a Denon DCM-380
hi
check in the link
SOURCE: Pioneer DV535 Player
That sounds like a problem that needs professional service. The door may have jumped a gear, or there could be a circuit malfunction. At any rate, it's probably cheaper to buy a new DVD player. CD and DVD technology are quite precarious still, and I wouldn't expect more than a couple years service from most DVD players.
SOURCE: My Pioneer CLD-990 only plays through one side of
One of the common causes is a small crack in the ribbon cable that connects the optics assembly to the PC board. This cable is moved all the time when the optics move and when the assembly turns over. This is not a repair I would recommend to a novice. The cable is still available last time I checked and is simple to replace for anyone that has worked on these before. The tray must be removed to do this and it is tricky to re-align properly. I think the cable runs between $20-$30.
Dan
SOURCE: DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
