Question about Btc 9039URF III Keyboard Trackball Mulitmedia Controller
99039URF keyboard/mice track ball not working
I own a 99039URF key board/mice, but when i paired it to my computer, all the keys on the keyboard can work except the mouse track ball. can any one help me ? Same problem, it moves up and down, but right to left, it only goes to right spontaneously. Can't use mouse or keyboard function. Mine is 9019URF
  • dramrfarouk May 31, 2009
    the mouse function is built in. It is working fine in only one axis. I installed drivers, however this works with HID windows drivers and is being well recognized by the system. I believe it couls be a hardware or a wireless connection problem. What is strange is that I received a replacemnet and gave me the same exact problem. this is also happening on different computers, running XP or vista.
  • 1,800 Answers
Well u can try installing a driver that may help some times also check the batteres on the mice!
Posted on May 31, 2009
Backspace key does not work on samsung bluetooth keyboard. device is paired and other keys work.
Re-pair the keyboard, if that doesn't fix it you will need to replace the keyboard.
Nov 04, 2016 | Samsung Computers & Internet
Pair to iPad
Till now I did not know you could pair a mouse to an iPad. When someone is selling mice you can connect via bluetooth, they will give you the manual to. I hope you know, the iPad is not a computer on which you can connect lots of things. Only when Apple allows you to put anything on, or connect via bluetooth, it can work. Not when you think it should be great.
Because Apple made it possible to connect their key board to the iPad, you now can buy third party keyboards that work with the iPad.
Jan 30, 2015 | Ckeyin Mini Optical Bluetooth 3.0 Wireless...
My lenovo keyboard is not working.i have three blinking lights above number lock
Is it a corded or non corded keyboard. Possible problems with non-corded: Dead Battery, no link to USB receiver(dongle) on computer, bad USB receiver (Dongle) on computer. From Lenovo Website:
Keyboard and Dongle Paring:
Auxiliary tools: PC with Windows XP or Windows 7, two AAA cells
Pairing steps:
1. Insert Dongle into PC. Be sure that the Dongle is recognized by PC and the distance between keyboard and the Dongle is within 10cm.
2. Press down F2, F3 and F4 at the same time, install cells, release F2, F3 and F4 and then Press "3" to begin pairing. After finishing pairing, press "Windows" key to check whether the pairing is successful. If "Windows" key works, it means that the pairing is successful; otherwise, the pairing fails.
That was all I could find on the site.
Sep 22, 2014 | Lenovo Keyboard
I'm tring to install the key board and the mice.
Keyboard and mouse are wireless so all you need is to make sure you fit good batteries and maybe you may need to press a pairing button to make the PC recognise them.
Jan 18, 2014 | Acer Aspire M3970 Desktop Computer
My KEY BOARD IS NOT WORKING
1. Restart your Computer at once. 2. If it doesn't work Turn off your computer and remove the keyboard from your computer and replace again. 3. If it doesn't work too, you need to change the key board. thanks
Aug 30, 2011 | Gateway 2520915 Keyboard
In compaq laptop in that all the key r working proper but only MNLK is not working. insted of 0123 is coming plz help me
It is possible that the shift key is shorted or there is fault on the keyboard track. If you look closer to the keypad button there is a shift key for using the M or shift to using 0. So this section could have faulted. It is ideal to remove the keyboard, remove all screws on the back board and remove and clean the pads. If not the keyboard is faulty in the tracks or the circuit.
Aug 22, 2011 | Compaq Keyboard
My Key Board is Not Working
The swapping process you have used already have clearly shown that your keyboard is faulty. It may be that a key is pressed down permanently / faulty and this blocks the signalling - check all the keys carefully to ensure none is depressed. Or one of the Connector pins (the part that goes into the computer) is bent - you may need to check and use a tool to straighten it.
But it is good to know that Keyboards are cheap to replace. If the above did not help, you can buy another keyboard for as low as £5 and then continue enjoying your computer.
Apr 30, 2010 | Lenovo Keyboard
How do i get a broken key replaced?
If your keyboard has a retail warranty, take it back to the place you purchased it from for a replacement.
If you don't have a warranty, feel free to take the key off by gripping it with a pair of pliers and gently pull the key out. Most keyboards have similar key mechanisms, so you could replace the key with one from another keyboard. This is mostly trial and error.
If by broken you mean the key doesn't register on the computer when you press down on it, feel free to take the keyboard apart (remember how you did that!) and give it a quick once over with a mildly damp cloth. Keep moisture away from circuit boards, however, as this could short them. Make sure the keyboard is completely dry before putting it back together.
Here is a guide if you need any assistance:
http://www.ehow.com/how_2316105_take-keyboard-apart.html
Hope this helps.
Apr 03, 2010 | Logitech Wireless Access Duo Optical...
I've got same problem at first time. After several trials, I could manage to work the whole unit by removing existing USB mouse. Just try to remove every input devices before connect it and follow the pairing instruction.
Good Luck!
Mar 28, 2009 | Btc 9039URF III Keyboard Trackball...
Btc 9039URF III Keyboard Trackball Mulitmedia Controller Logo
162 people viewed this question
Top Btc Computers & Internet Experts
David Payne
David Payne
Are you a Btc Computer and Internet Expert? Answer questions, earn points and help others
