Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
My jenn -air self clean over just beeps when i hit clean
No manual to my 5 burner duel fuel jenn-air.
I can't get the cleaning cycle to start on double ovens it just beeps.
  • Jenn-Air Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean (self destruct) mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on May 18, 2010
Two from burners will not start , unless a match is used
Check the position of the ignitor that sparks, compare it to the burners that do lite.
The other one may ne replacement
Mar 18, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
1. Close the oven door.
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
self-cleaning operation will be canceled and the display
will return to the time of day.
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Top burners spark intermittently with burner valves shutoff
Remove the burner caps (where the gas and flame come out) and wash in warm soapy water, using a plastic toothbrush like brush to scrub thoroughly.
Also clean/scrub the burner bases and ignition knob on the top of the cooktop.
When you reassemble, make sure the burner caps are properly seated in the burner bases.
Jan 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Self clean oven doesn't work
hi there,
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
Nov 17, 2008 | Ovens
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Should I???
Make sure that you will be happy with this unit. The ovens are fairly small and you will have to bend alot to use the lower oven. The only problems my company have run into so far are the control boards and not getting very clean following the self clean cycles. Good Luck
Mar 31, 2008 | Jenn-Air JDR8895AA Dual Fuel (Electric and...
Oven won't lock and self clean.
Shut off the oven for at least a minute and turn it on, set the clock, and it worked. I had tried a short power cycle before and it didn't fix it. The extended power cycle did the trick.
Mar 01, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Oct 04, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
345 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
