Question about Epson Stylus CX9400 Photo Printer
Scanner bulb doesn't turn on during a scan
Epson cx9400 printer fax scanner combo. My scanner light doesn;t come on for the scanner to work properly. Any ideas what I can do to fix this?
  • 256 Answers
You can try to get and replace the scanner light. If it was the light, the new one will work. If it was some other electonic component that shut off the light, then the light won't work. Depends on the cost of a new light compared to getting the unit serviced by a tech. Or the cost of a new Multifunction unit. Do some research before you make the decision.
Posted on May 31, 2009
How to open up an epson 9400fax to clean
Page 16 of the manual shows you how to properly clean your Epson Stylus CX9400.You can view the manual here:
http://www.manualbuddy.com/3570/epson-stylus-cx9400-fax-user-manual
Jan 30, 2013 | Epson Stylus CX9400 Photo Printer
The scanner light on my epson 1670 fluctuates in intensity during scans which produce darker bands across printouts
check the power souce is conected properly it may be the bulb or pwer converter inside cheapest fix is to replace the whole unit.
Oct 06, 2010 | Epson Perfection 1670 Flatbed Scanner
Can't send or receive
fax machines are analog devices and will not work reliably on a digital phone line.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Epson cx9400 printer/scanner/fax
Follow these steps to print a nozzle check:
  1. Load letter-size paper in the sheet feeder.
  2. Press the cp_button_1.gif On button to turn on the Epson Stylus CX.
  3. Press the Setup button.
  4. Select Maintenance and press OK.
  5. Select Nozzle Check and press OK.
  7. Press the cp_button_6.gif Start button to print a nozzle check.
  8. Shown below are some examples of what the nozzle check may look like.
Mar 01, 2009 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Fax
From your Win Vista Computer;
1.) Try to uninstall ( epson scan ) in the Control Panel / Programs and Features ones it is removed.,
2.) Download TWAIN Driver and EPSON Scan Utility v3.20A > epson12384.exe
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90753&prodoid=63070382&infoType=Downloads&platform=Windows
3.) Ones it is downloaded and installed to your computer., try to launch epson scan ( if same issue persist )
>> On the Device Manager (Vista) if the Epson Scanner is listed under "Other Devices" -- with a yellow " ! " < right click on it and click on update driver., make sure that the option selected is " Install the software automatically (Recommended) and then press next > ..... you may need to restart your computer after this procedure..
>> Then try to scan again
Note >> if a pop on your computer for ( New hardware Found ) just ignore it / close it., after the scanner driver is installed it will go away.....
Jan 31, 2009 | Epson Stylus CX9400 Photo Printer
EPSON CX9400
Did you hit the Auto Answer button? The green light next to it should be on.
Jul 30, 2008 | Epson Stylus CX9400 Photo Printer
OCR
To scan a document for editing purposes, you will need OCR (Optical Character Recognition) software. OCR software is not included with your model.
OCR software interprets the scanned document for editing purposes. The Epson driver alone only scans documents as image files and is not capable of this interpretation.
Some reputable OCR software programs on the market are:
Omni Page Pro
ABBYY FineReader Pro
Presto! OCR 4.0
Please understand that Epson has NOT tested our products with these programs. They do not know if these programs are TWAIN compliant and will import directly from our scanners. I recommend that you contact these companies for full compatibility information if you are interested.
Jun 01, 2008 | Epson Stylus CX9400 Photo Printer
Help
no.you need dial tone to send faxes. dsl is for computer use.
wg
Feb 10, 2008 | Epson Stylus CX9400 Photo Printer
Cx9400fax
Epson Quick Guide is incorrect.
Not sure of your exact situation but .........
Your answering machine MUST be connected directly to the output of your CX9400 and you can't use an answering machine with multiple "mailboxes". Set your answering machine to 4 and your CX9400 to 5/6 rings. Epson "Technical Support" has no clue of this problem .... yet.
The machine routes the call to your answering machine, it it's an incoming FAX and the answering machine starts the CX9400 will recognize the incoming transmit signal, turn on the FAX function, and disconnect your answering machine.
You may need to adjust the CX9400 rings setting based upon the duration of your answering machines announce message (longer message = greater number)
Jan 28, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
