Question about AMC Multimedia AV81HTC-DD 6-Channel Amplifier
No sound from my amp.
I git sound thrue my amp when i play my stereo thrue it,i git no sound from my amp when i try to play my guitar thrue the amp.
  • Samuel Charles Spriggs May 11, 2010
    How & where are you connecting the guitar?
Amp not comming on until strings played hard.
Check your cables - I've had similar problems with various amps playing various guitars; the guitar electronics and the amp electronics are fine, but the cable is damaged internally and this causes the same problems as you have described. Have you tried using a different cable? Buy a different one, try it out, and see if you have the same problem. If you have a friend who plays, let them plug their cable and guitar in the amp - if it works, your faulty cable is the issue. Hope that helps!
May 01, 2013 | Genz Benz Shenandoah 150lt Acoustic Amp...
Hi there, I just changed my tubes and re -biased. When I plugged my guitar in there was no sound from the amp until I git to about 6, and the sound was popping and crackling struggling to break through. I...
If it worked before you changed the tubes, it is possible one of the replacements (probably a small tube) was bad... it happens... Another possibility is that a socket pin has gone bad or a pin has broken or bent off... again probably one of the small ones... 12AX7/12AT7 or equivalent.
Swap old ones back in one at a time.
Jan 10, 2011 | Fender Hot Rod Deluxe Guitar Combo...
I have a Marshall MG100DFX. I turned my amp on a few days ago and I heard this loud sound (not the standard hum/buzz that you hear when you plug a guitar into an amp; it sounded more like a foghorn). Now,...
I would try hitting the side of the amp before turning it on. There may be a loose piece of solder or other conductive particle stuck somewhere. Bang the cabinet rather hard with your fist. If that doesn't help it might be a loose solder connection at a resistor or capacitor but a tech should check that out.
Dec 04, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I PLUGGED THE GUITAR INTO THE GUITAR INPUT AND PLUGGED ANOTHER JACK INTO THE SEND UNIT TO MY AMPLIFIER BUT CAN'T HEAR ANY SOUND EVEN THOUGH I GET A READING THAT SHOWS SOUND IS HAPPENING. THE OL LIGHT IS...
try this: plug a stereo headphone into send & check if you get something on one side of the headphones (should be left side) if yes check the cable you use, it's possible that a mono plug (as used for guitars) is disabling the send output, using a stereo plug & adaptors may work (especially if you get the sound in the right side of you headphones check also the manual you may find a description how to connect/insert a guitar effect when recording or live mix
Nov 12, 2010 | Tascam Dp-02cf Digital 8-track Recorder
No sound
You would NOT use a stereo cable to plug in your guitar.
The stereo cable would carry the battery voltage back to the amp and MAYBE cause the fuse to blow.
You use a MONO instrument cable for your guitar.
The ring connection is use to complete the circuit to turn on the battery in most guitars.
Replace the fuse ONCE and get the proper instrument cable (NOT consumer audio cable) for your guitar.
If fuse blows again, take amp to shop for service.
May 30, 2010 | Peavey Valveking Head
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Guitar hero II controller doesnt play
Try setting the sound in options to mono instead of stereo.
Dec 26, 2007 | Video Game Consoles & Games
Guitar hero 3 Wii Edition
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 23, 2007 | Nintendo Wii Console
Lexicon lambda
push the monitor button to go mono instead of stereo.
Oct 11, 2007 | Lexicon Lambda Usb Desktop Recording...
AMC Multimedia AV81HTC-DD 6-Channel Amplifier Logo
35 people viewed this question
Top AMC Multimedia Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AMC Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
