Can't receive wireless signal from main computer
I have a wireless computer that is not receiving the signal from our main computer. It states that the problem is inaccessible to the access point. What is my solution?
  • 3,600 Answers
You have to make a new wireless connceton and instal the serial number off of the wireless modem in to the new computer to set it up to recive and send on the network you also have to set up network shares and need to be the administrater to do so,
Posted on May 31, 2009
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
Gateway wireless keyboard detection
Insert the installation CD that came with your wireless keyboard set into your computer's CD-ROM drive.
Use the CD to install the drivers for the wireless peripherals.
Insert batteries into the keyboard .
Use a screwdriver to remove any screws that hold the battery bay covers closed.
Connect the wireless signal receiver to your computer.
Receivers for wireless keyboard and mouse sets usually use a USB connector.
Your computer will automatically detect the receiver.
Turn on your keyboard if the devices have power buttons.
Press the "Sync," "Connect" or "Pair" buttons on the keyboard , depending on your model.
If present, press the "Connect" button on the wireless signal receiver as well.
Your wireless keyboard set is now connected.
hope this helps
Oct 13, 2012 | Gateway One Computers & Internet
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
How do i make the atomic clock work on my wireless thermometer?
The main clock need to be located close to a window.
Although the signals often pass through the walls of a house, they can also be blocked by the metal in the walls.
Also if the clock is located close to your tv or computer, the signal may be blocked.
Good Luck!
Jan 03, 2010 | Audio Players & Recorders
My comp wont recive my wireless signal it started getting slower reception over like a two week period then nothing any idea. It's the network receiver in my main computer. Every other computer works.
If some other computers are working so the problem here is with the wireless adapter on that computer, the best thing that you can do here is to update the driver of the wireless adapter or you can also uninstall and reinstall it to correct the problem..........
Oct 16, 2009 | D-Link AirPlus DI-524 Wireless Router
Computer stopped receiving wireless router signal
In this order: 1) Turn off all PCs and printers connected to the router. 2) Unplug your router's power cord. 3) Unplug your modem's power cord. 4) Wait for at least 2-3 minutes. 5) Connect the modem's power cord and wait for at least 2-3 minutes. 6) Connect the router's power cord wait for at least 2-3 minutes. 7) Turn on each PC separately and wait until it is completely finished booting before turning on the next PC.
If you still do not have connectivity, read the manual and change the channel of the modem. YOu may be experiencing some RF interference, ie microwave, wireless phone system etc...
Oct 29, 2008 | Linksys Wireless-G Broadband Router
I'm trying to connect my computer to my Sansui A3100 receiver so that I can listen to my computer music via my speakers which are also hooked up to my receiver. Everything is hooked up correctly. Can you...
I would connect the computer directly to the speakers not the receiver to confirm the impedance is compatible. Connecting via the receiver complicates the issue.
Which output channel are you selecting on the receiver.
Oct 12, 2008 | Sansui Audio Players & Recorders
Computer monitor comes on for 1 seconds, flashes "analog power save mode" and then goes black.
Most monitors will say "Power save mode" when they can tell through residual voltage that the signal lead is plugged into a machine, but there's no picture being transmitted. The four states of a monitor are:
* Off entirely.
* Switched on, plugged into a computer but no video signal being received - usually displays "analog power save mode" or "digital power save mode" for a few seconds, then blanks. Comes back to life the moment a video signal is received. This state is the default in full power saving mode.
* Switched on, not plugged into a computer. Some monitors don't display anything, some go into power saving mode, some fly "CHECK SIGNAL CABLE" or a similar message around the screen. Picture is restored when the signal cable is plugged back into the computer
* On fully, receiving an image, and displaying.
Hope this helps.
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
