Hi, the Cisco router stopped broadcasting suddenly! the computer is connected to the internet hardwire. I turn it off for a time and turn on and I did reset, but still not working. My computer is Windows 7
SOURCE: belkin router
A couple of items to check -- these will not fix the issue but may isolate the problem.
Turn all machines on before the test and do not turn off until after
On at least one wired computer that is working and maybe all wireless computers I want you to do the following
Click Start then All Programs then Accessories then Command Prompt
In the window that opens type
ipconfig /all
press enter then record all of the following for each adapter
The back in the window enter the following command using the default gateway from the wired connection (your router address)
ping (default gateway)
you will either get 4 timeouts -- the connection fails or 4 messages with elapsed times generally measured in ms or milliseconds.
What you are looking for in the above
Good entries base
x.y.x match each other if subnet mask is right
u should be unique for the network
Wired IP address x.y.z.u not 0.0.0.0 may be 192.168.0.u
SubNet Mask ?.?.?.? assuming 255.255.255.0
Default Gateway x.y.z.? not 0.0.0.0 may be 192.168.0.1
DNS addresses ?.?.?.? not 0.0.0.0
where at least one is not zero.
Then wireless entries should be
SubNet Mask same as wired
Default Gateway same as wired
DNS addresses same as wired
If these are wrong there is a configuration error either in the router or wireless adapters depending on how you want your network setup.
each connected adapter wired and each wireless should also
successfully ping the default gateway or router address
If the ipconfig is right and the wired config has successful pings, then every wireless adapter that fails has a wireless config issue.
If you are willing to work through this let me know and reply with information in a comment to this issue.
You may also want to address wireless security
See this response and let me know what you want to do.
Wireless security
SOURCE: WRT54G wireless router is not broadcasting wirelessly
Is the WLAN or Wireless Light lit on the front panel of the router.
SOURCE: Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
SOURCE: My router is not broadcasting wirelessly
their is option in setup to enable wireless or disable it go to modem setting page and enable wireless function
SOURCE: My NetGear WGR614 v1 stops broadcasting and needs to be repowered
I suggest you do a firmware upgrade. But in doing this, you will loose the settings on your router. You have to reconnect all you devices on the new settings.
Please follow this steps:
2. Download this link ftp://downloads.netgear.com/files /wgr614v1_1400.zip
3. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
4. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
5. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
6. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Setting the router:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://192.168.0.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
