Question about Apex Digital PF3220 32" TV
Finding a code
I need to know where i can fine the code for my remote for my APEX TV and the other number is CK5G-C1? I changed the batties and now i need the code so i can program my remote for the tv?
  • 1 more comment
  • Anonymous Nov 26, 2007
    i have a apex gt1417dv and i need the code so that the dvd side of my dvd / tv combo will work! the tv works fine wth the remote - but no dvd action..... i have a magnavox remote
  • eightfm Nov 26, 2007
    i have a apex gt1417dv and i cant get the dvd side to work...only the tv side of the dvd / tv combo....
  • anitafaye Oct 09, 2008
    I have the same problem with the same remote. APEX CK5G-C1
What is the model number of the Apex TV you are using this remote for?
The CK5G-C1 remote was supplied only with model AT3208S TV. It will require no code when used with that model. If trying to use it with any other model TV, you can try the other Apex TV codes found in the AT3208s user's manual that can be found in .pdf format at : http://www.apexdigitalinc.com/manual/AT3208S.pdf
Let me know if this helps, or I can be of further help.
In any case, good luck!
Posted on Oct 25, 2007
I need a code for an apex tv i have a phillips universal remote
Posted on Jan 07, 2009
Will apex ck5g-c1 remote control program to rca dolby digital analog pass through analog converter stb7766c
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 20, 2016 | RCA Televison & Video
How do i remove key symbol onpicture of TV
The TV is locked. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure to many popular brand TVs are given.
Oct 02, 2014 | Televison & Video
How do I unlock an apex at2704 with an At&T uverse remote?
These are the steps to unlock Apex TVsApex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Sep 02, 2012 | Apex Digital Televison & Video
Need samsung remote codes for apex tv
Go to www.apex.com and query for the manual to the controller
Jun 17, 2009 | Televison & Video
Need a model number for what remote came with my GT2015DV
if is the tv in the pic the model # for the remote is kdt1a-c1
Oct 07, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Code for apex tv through philips universal remote
Go to www.urc.philips.com/
Follow the steps..its easy. It will ask for the model of your remote which you will find where your batteries are located..The code I used for my APEX tv was 0023.. to load the code first hold the setup button until the red light stays on..then press tv or whatever mode you are setting up..then enter the code and if the red light goes off it is the right code and you should then press channel up to see if it works...If this code doesn't work the site above offers other codes.. Hope this helps!!
Aug 30, 2008 | Apex Digital ADV3800 DVD Player/VCR
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
May 02, 2008 | Directed 434MHZ Remote Control
Remote contol volumn won't work
The buttons themselves may not be making contact. I've had to take some remotes apart and clean the carbonized rubber pads that touch the contacts on the circuit board. Most remotes can be pryed apart very carefully and cleaned. If this doesn't help it is possible that the incorrect code is in the remote. Also part of the chip that generates the digital pulses could be bad. You might need to get another remote. Stargazer
Aug 11, 2007 | Apex Digital PF3220 32" TV
Apex Digital PF3220 32" TV Logo
1,555 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
