Question about RCA B27TF680 27 in. TV/VCR/DVD Combo
American DVD discs will not load and play, but overseas discs will
I have an RCA DVD/TV/VCR combo. I have been using and playing DVD for 6 years with no problems. I was out of the country and bought some DVD's. Since I am back, the American DVD's will not play, but for some reason the ones I bought overseas do play. If the combo player is region one, you would think it would not play the overseas DVD's. Could having put the overseas DVD in the player have caused some change in the coding? If so, how do I change the coding back to 1 if this is the problem? Tim
  • 26 Answers
No the coding would not change from using the dvd's from overseas. the ones that you say are american may not be american and that is most likley the problem. try putting in a dvd that you have had for a long time that you bought here in the states and if that works then the dvds you say are american are the problem.
Posted on May 31, 2009
I was just wondering if Magnavox Dvd/VCr combo MWR20V6 is a multi-region dvd player?
all dvd players are region free when you first buy them, they set the region themselves, after 5 dvd's have been played on them. So if you had a european dvd player and played 5 USA dvd's on it , it would lock to the USA region and you would be unable to play european dvd's on it. Exactly what a friend did many years ago when he bought a load of american dvd films from someone and played them on his brand spanking new dvd player :)
Apr 10, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Doesn't play dvd that it used to, states wrong disk type
the disc you inserted has region please insert the right region match to your country
Jun 18, 2010 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
Connected samsung dvd vcr combo to samsung lcd series 6 tv via componet cables dvd works fine vcr playing but no picture help me. gordy
all i did was disconnect the component cables and connect using the rca cables and everything worked fine.
Jul 06, 2009 | Samsung Televison & Video
Problem with DVD/VCR RCA DRC8335
More than likely the DVD drive in your unit is bad.
Feb 27, 2009 | RCA DRC8320 DVD Recorder/VCR
Unit will not record DVD's
remove cover clean burner eye a little toilet paper,put a little grease on linear bearings, very little using a toothpic use verbatim dvd rw discs from cdw inc. 1x4 speed
Jan 22, 2009 | RCA DRC8300N DVD Recorder/VCR
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
RCA B27TF680 27 in. TV/VCR/DVD Combo Logo
233 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
