Question about LG LP6000ER Air Conditioner
Ice on coils
Ice in coils
  • Complectric May 11, 2010
    Do you have a filter in place? When was the last time you cleaned it?
    President:
  • 2,559 Answers
This is usually due to a clogged filter or coil,Make sure the coils and filter are clean,Listen to make sure the fan is running,If all is clean and running,the unit will need to be serviced.
Posted on May 31, 2009
We have a several Scotsman ice machines but on one the evaporator is a block of ice. What can cause this to keep happening?
There could be several causes.... Dirty Condenser, Drain Tube Issue, faulty evap fan, etc. Go through the list below to help you diagnose the issue. The second website is even more in depth.
Iced Coil evaporator coil iced problems with iced coils
http://www.achrnews.com/articles/87866-six-steps-for-ice-maker-diagnostics
Nov 17, 2016 | Kitchen Appliances - Others
Ice on coil
air purifiers do not cool anything .
Jul 06, 2016 | Air Purifiers
Why is it building up ice on three coils?
Hi, for your air conditioner you'll have refrigerant coming from the compressor (cold) to the coils - when it leaves those coils - the refrigerant has basically absorbed that heat - and it's on its way out to the evaporator - sometimes the other set of lines actually gets hot. If you have ice on your coils - could you check your fan and make sure it's operating correctly. The absolute only thing keeping those coils from icing up is the fan drawing air over the coils - no air/not enough air flow - it doesn't function properly and your coils will ice up.
Jan 25, 2016 | Heating & Cooling
WHY IS THERE WATER IN BOTTON OF FREEZER AND ICE MAKER NOT MAKING ANY ICE
You have an iced up evaporator (cooling coil). This coil is usually located in the freezer section. A small fan distributes air across this coil and into the refrigerator. If coil is block with ice, no air can be blown across the coil. Coil is blocked with ice due to failed defrost timer on main circuit board or a failed defrost heater.
Jul 14, 2014 | LG Refrigerators
Iced up coils
Iced up coils always means a lack of heat load on that coil. This may be due to fan failure, dirty blades on the fan or "squirrel cage", dirty air filter. If the outdoor coil in a heat pump application is iced over, possibilities are: fan failure, dirty fan blades, outdoor ambient temperature too low, or failed defrost timer or ice sensor.
Nov 07, 2013 | Heating & Cooling
Coil icing up
make sure the filter is very clean. make sure all supply grills are unblocked and open. make sure the indoor fan is blowing. icing coil is normal during heating mode the system will defrost using a sensor. sometimes during cold wet weather the coil will stay iced up. sometimes in cooling mode when it is cool outside 60 degrees or less the coil will ice. low freon will make the coil ice up ,also defrost control not working will cause the coil to ice up
Sep 06, 2013 | Goodman PHKJ048-1 Air Conditioner
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice buildup on the coil and ice buildup on freezer floor
you will have to unclogg it..hot water/hairdryer..flexible tubing to push out the clog. the ice on evap coil bothers me though. do all the coils get frosty white(close the door for 10 minutes then check) I fear they aren't and you have a freon leak.
Jun 13, 2009 | Refrigerators
Icey coils,replaced bunrt defrost heater coils still ice up
Replace defrost timer and defrost thermostat.
May 13, 2009 | GE Refrigerators
Ice on the coil fins of my Window AC unit......
set your unit to fan mode only, to thaw the ice, after the ice melts, look at your evaporator coil, see if its dirty, if its dirty, then you might just need a good cleaning. if the coil is clean, look at your thermostat setting. it should not be all the way cold. the compressor would run continously and it would freeze the coil. third, the refrigerant system could be partially clogged up or it lacks refrigerant. these problems initiate freezing of the coil.
Feb 18, 2008 | Carrier 52PQ307 Wall/Window Air...
LG LP6000ER Air Conditioner Logo
118 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
