Question about Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case
My garmin nuvi 260w wont turn on. I used a charger that it wasnt used to and the whole thing just shut down. It wont turn on i tried the origanal charger, i tried pluging it into my computer, i even tried it reset button nothing works. What do i do????
  • Garmin Expert
  • 343 Answers
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu.
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
Posted on Jan 18, 2010
Garmin nuvi 260 battery does not hold a charge
If a wall powered charger is used it could be bad or the connection from it to the unit damaged---happens if the charger is connected/disconnected a lot----same thing can happen if using the lighter plug adapter for charging.
Nov 06, 2012 | Garmin nuvi GPS
My garmin nuvi 260w want hold a charge
bad battery or voltage not reaching from the charger--I would test for voltage first from charger or if using lighter adapter the fuse in it.
Nov 06, 2012 | GPS
When i charge my garmin nuvi 260W with a car chager, the screen would be stuck, and i'm not able to use it.?
garmin are very fussy about there chargers if its the original charger then there is a fault with it if its not the original then get one ( you can only use genuine garmin chargers for garmin gps units) they have a clever sensor in them that stops you from using any other type of charger
Jun 28, 2010 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
Gps in sync mode when using charger
Wrong Charger....
Get the Garmin charger. That WILL work for sure.
I know, I did the same thing!!
Jun 02, 2009 | Garmin nuvi 260W GPS Receiver
Proper charging advice for Nuvi 260w
Turn it off and Always unplug it when you're done with it.
That's assuming you have a live plug (stays on when car turned off)
Mar 16, 2009 | Garmin nuvi 260W GPS Receiver
I game my parents a garmin 260w with just the car charger.
I would only us the Garmin charger. Why take a chance. They are fairly cheap. Plus you need the car charger since that's where you use it most of the time. The batteries don't last all that long.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
BROKEN GARMIN NUVI 260W
Have you tried pressing the reset button on the bottom where the decal is?
Dec 18, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case  Logo
278 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
