Question about Hampton Bay 48 In. Palm Beach in Textured White Fan
Install new light bulb
Can't find the instruction manual and do not know how to take the light cover off to replace the light bulb. Any suggestions.
  • 323 Answers
If it is a dome light then there will be 3 small screws tha screw into the dome at the very top, spaced evenly around it.
The friction from the screws holds the dome in place. Chenge the bulbs and fit the dome back in, screwing all three screws in partially. Then hold it firmily up against the fan base and tighten one til it makes contact. Tighten the other two the same way and when the dome is secure, tighten all 3 screws so it doesn't come loose.
Posted on May 31, 2009
SilverCrest Microwave SMW 800 A1 Bulb replacement instructions please
You have to remove the outer cover but be aware that after removal you are exposing yourself to potentially lethal voltages even with power removed. Remove the old lamp and install the new lamp you have kept on hand for this occasion. Reinstall the cover but test operation before reinstalling all hardware in case the replacement lamp does not work.
Aug 16, 2016 | In Microwave Ovens
How to replace light bulb
You can download GE owner's manuals and installation instructions here.
If they don't cover replacement of the bulb, you'll have to take the cover off the oven.
ALWAYS unplug the oven before removing or installing light bulbs, or a surge can occur, requiring circuit board repair.
Dec 04, 2011 | Microwave Ovens
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Does anyone know how to replace the light inside the oven? not the light that shines down. The oven does not light when you use it. The GE manual does not seem to have any information on this or any of...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If there's no obvious removable cover over the bulb and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (and 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jul 09, 2009 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
Light out
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 14, 2009 | Sanyo Microwave Ovens
The interior light on my microwave convection oven doesn't light.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Nov 20, 2008 | GE JVM1490 Convection/Microwave Oven
How do you replace the interior bulb in a Model JVM3670BF08
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
hope this helps dont forget to rate this
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Neff Combined oven and microwave
Nov 03, 2008 | Neff H5470 Microwave Oven
Light bulb change
You can download Frigidaire owner's manual and installation instructions here.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Aug 03, 2008 | Frigidaire FMV156DC Microwave Oven
We need to know how to replace a magic chef microwave light bulb, please!
If you don't have your instructions, please reply back with your brand and model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Magic Chef Microwave Ovens
Hampton Bay 48 In. Palm Beach in Textured White Fan Logo
199 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
