Question about Sony Cyber-Shot DSC-P200 Digital Camera
Not able to turn flash on and off
Right now it show flash offf and i not able to make any changes
On the back of the camera there is, on the multi directional pad at the top something which looks like a lightning bolt. That determines if the flash is off/on or the strength of the flash.
Try to reset the camera, remove the battery, etc. and try again if this does not work.
Posted on May 31, 2009
Kitchen scales
try changing the battery (s) and see what happens.
Apr 12, 2013 | Taylor Kitchen Scale – (6 lb) ()
I phone wont turn on
Remove your battery and try again
Jul 09, 2012 | Apple iPhone 4 Black Smartphone
The engine keeps turning off as you drive
Possible fuel injectors leaking rough idle hard to start when warm
Dec 03, 2011 | 1997 Jeep Grand Cherokee
Change time/change settings ie: alarm
Hi pboucher445,
You can easily change the time of your Timex watch by following the steps below.
1. With the time and date showing, press the top left button.
2. Press the right top button (this sets seconds).
3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
5. Press the bottom left button, month flashes. Press the top right button until correct.
6. Press bottom left button, date flashes. Press the top right button until correct.
7. Press bottom left button, day flashes. Press right top button until correct.
8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
Hope it helps.
Thank you for using FixYa.
Nov 08, 2010 | Timex 1440 Nylon watch
My D530 will not start up there is just a green flashing led
First check num lock key on key bord when u press it numlock led is on and offf.if that led on and off then your cpu is ok then you need to change screen resolution
when you power press F8 key then enter in enable vga mode then go to control panel ->dispaly ->settings then change screen resolution to 1024*768 then aply and ok then restart it.
But if num lock key not onn and offf then you need to open cpu cabinet then reattch all connection to mother bord also reattch connection to harddisk.
Also pull cmos cell for 15 minutes then refix it then all settings of bios are reset to defaults.
then check.
Please rate my solution if you tihnk that i help ful to you.
Thanks for using fixya.
Jul 17, 2009 | HP Compaq Business d530 Ultra-Slim PC...
Poineer vsx-810s amplifier
If it flashes AMP_ERR, one of the chipamps is shorted & needs to be replaced.
Apr 17, 2009 | Pioneer VSX-818V-K Receiver
2004 alero
If the security light is flashing when that happens, you need to turn the key to the ON position, and let it sit for 10 minutes, so it can reset the security code. Start it up as normal and let it idle for 5 minutes.
Nov 04, 2008 | 2004 Oldsmobile Alero
Prospirit watch
in order to SHUT OFF THE ALARM:
go to the normal time setting, where nothing is flashing. then press and hold reset. then the time you want the alarm on shows up. in order to turn the alarm off press start...press start again to turn it on
May 15, 2008 | Watches
Sony Cyber-Shot DSC-P200 Digital Camera Logo
53 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
