Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Drive belt keep falling off
Drive belt falls off when i push clutch pedal in
  • 284 Answers
You have belt guides near your pulleys that helps to keep the belt on during no engagement
you need to check to see if they are missing or bent and adjust as close to the pulley and belt as possible without interfereing with the belt and pulleys while engaged.IE: no rubbing against the pulley or belt while engaged or moving.
Posted on May 31, 2009
New drive belt still won't pull tractor
Your belt was probably not placed over the tension pulley. Follow the pedal you push to make tractor go forward. Look under the tractor where the belt was installed. If space is tight just lower your deck. The linkage from the pedal will go to the tension pulley. If the belt has been placed on one side of the pulley, and machine is not working then move the belt to the other side of the pulley. Replace any bars that are used to keep belt from falling off. I am interested in hearing back from you. GOOD LUCK FRIEND.
Sep 17, 2014 | Cub Cadet Garden
How do you install a gas peddle for 69 vw
now that is a hard question, it's tricky
the pedal base, has a base pin, seen here.
and a spring,
you most remove the whole assembly (making clutch fail )
cable falls off in tunnel.
then pull the pin, and put in new pedal.
the steps for the clutch are complex.
http://www.no-agua.net/At_Wits_End/new-pedals.JPG
the cable, falls off , what to do, id replace it first. that old cable..
sure would.
http://www.no-agua.net/How_to_fix_it/clutch/clutch-all-issues.html
Jul 13, 2014 | 1959 Volkswagen Beetle
I have a 2005 isuzu diesel bakkie.When the engine is cold everything is fine,but after driving about one kilometer if i use the clutch the idling fall and sometimes it stall,if i release the clutch it
pull of the cover under the fly wheel(bell housing) and see if you can turn the throw out bearing with your fingers . If it is jammed then it will be box out to replace the bearing There should be a bit of clearance there to be able to do this
Dec 25, 2013 | Cars & Trucks
My clutch pedal is not working. falls right to the floor. have to drive by hard-shifting. in my '88 audi 90 quattro
You have a leak and will need to replace the clutch master and slave cylinders.
Jun 11, 2012 | Cars & Trucks
How do you know if it is the fan clutch, the
I would check to see if the cooling fans are coming on. The fans could be bad or you may have a blown fan fuse or fan relay.
May 18, 2010 | 2002 Jaguar X-Type
MY HOT AND COLD METER KEEPS RISING AND FALLING
If the fans are electric, then replace the fan control module.
If the fan is belt driven, replace the fan clutch.
There is a chance that the thermostat is failing, but if the temperature fluctyation occurs during driving, as opposed to stopped and idling, then it's probably the fans.
Dec 18, 2009 | 1998 Oldsmobile Intrigue
The serpentine belt keeps falling off. It has
spin all the pulleys by hand with belt off, make sure none are seized.
Nov 12, 2009 | 1998 Plymouth Voyager
Drive belt falls off mower
You need to inspect the pullies holding the belt, and the bearings that run the pullies. If they are bad they will jump the belt.
Oct 29, 2009 | Garden
Why does the drive belt on my 42'' lawn tractor fall off the rear drive pully every time I press down the brake / clutch pedal?
Raise the back end of the tractor off the ground and check to see if your transaxle has any forward/backward rocking movement. If it does, check where the bolts go through the frame and the transaxle housing see if they are loose or missing and also look at the frame to see if it has broken allowing the transaxle to move
Sep 15, 2009 | Garden
Yard Machine 18.5 HP riding mower,drive belt keeps falling off pulley & clutch pedal hard to press down??
ck belt for wear ck between deck and frame
for so thing around clutch shaft or shaft out place.
May 01, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
437 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
