Question about Sony Ericsson Z310i Cellular Phone
Hi there, ive got a sony ericsson and its crapped itself
First the screen went funny, now the screen wont work at all. everything else is working. it rings and receives txtx, its just the screen. its totally blank. ive tried removing the sim ans battery. but it hasnt made any difference. im not sure where to find its type either
  • 7 Answers
If it's a z310a (which it probably is, since a lot seem to have this screen problem) I can help you save your contacts to your SIM card so you can put them on a new phone.
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Posted on Jun 01, 2009
  • Zsolt Garami
    Zsolt Garami Dec 04, 2011
    You wrote "z310a", while mine is "z310i".
    Do you think that the same instructions can be applied there as well?
My xperia x10 has locked itself and is asking for my google account to unlock it. i didnt create one on the phine however i went on a laptop and made one but that still didnt work...ive tried everything...
peria X10 Hard reset SUCCESSFUlLY DONE this will also remove any password you have on the phone
DOWNLOAD PC SUIT FROM
http://www.sonyericsson.com/cws/supp...no?cc=gb&lc=en
1--install it ...THEN
2--LAUNCH THE SOFTWARE
3--PRESS TOOLS
4--PRESS PHONE REPAIR
5--PRESS CONTINUE
6--WAIT FOR THE SOFTWARE TO DOANLOAD FILE ONLINE
7--SELECT THE MODEL X10
8--CONNECT PHONE WHILE HOLDING BACK BUTTON AND INSERT USB
9-- LET THE DRIVERS INSTALL AND WAIT WHILE THE FLASHING COMPLETE
ALL DONE PASSWORD REMOVED
GOOD LUCK
Feb 28, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
Ive got a sony ericsson w580i cam phone
I have the same problem!! :( my phone works fine, except for the camera. when switched to camera mode the screen doesn't show anything. its black.
Mar 14, 2010 | Sony Ericsson Cell Phones
My sony ericsson k320i is completely dead and wont switch on with charger in, usb or on its own. totally lifeless; ive tried everything!
HI FRIEND...
the firmware may be corrupt...upgrade ur firmware..if no luck...im sorry ur phone completely dead..circuit is damaged...
please check it...
thank u...
PLEASE RATE IT
Nov 11, 2009 | Sony Ericsson K320i Cellular Phone
K530i broke.
its possible that the LCD got busted.. also, its possible that parts of the circuit board went bad. just bring it to the cellphone shop
Jul 03, 2009 | Sony Ericsson K530i Cellular Phone
Brken screen
if a new screen didn't work, and it was installed correctly, then you are probably S.O.L. the video driver probably crapped out on you
Jun 19, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Wont switch on
There is also a possibility of moisture as well. Sony Ericsson's are notorious for going white screen when there is moisture or corrosion in the phone.
To be completely honest regarding Flashing the phone... it is not easy and has many steps. I would recommend going to www.gsmhosting.net. There, search for forums on flashing the K800i software. To flash the phone, you will need a Cruiser Box, the correct cable, and the full software for that phone and your service provider. The K800i is DB2020, which is Sony Ericsson's most up to date encryption.
Believe me though, there is way to much involved in flashing the phone to post here. How long have you had it and if there is no moisture, have you considered a warranty exchange through Sony Ericsson?
Aug 07, 2008 | Sony Ericsson K800i Cellular Phone
My sony ericsson w890
Hi, the external and internal display has gone... is all black.. but the phone continues to work. I´ve shut it down and turn it up... but continues the same way. This cell is only 3 weeks old.
Can some one suggest a solution?
May 09, 2008 | Cell Phones
T610 problem
it's a hardware problem..check if the antenna(the green board at he back of the phone) has no loose contacts..
Jan 07, 2008 | Sony Ericsson T610
Sony Ericsson Z310i Cellular Phone Logo
384 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
