Question about Refrigerators
Noticable gap between door and frig ,need to bring door up
I have no idea where the cap is for the screw adjustment,if there is one.
How do I lift the door back in to place. The hinges are NOT BENT.
This has me crazy.
    Novelist:
  • 103 Answers
Hi: Some refrigerators had a plastic cam mounted on the bottom hinge to help the door close. The cam can break and be easily swept away. This will cause the door to lower and not close as well as it used to. I've seen GE's do this. Give me more info on the model. and I may be more help. Good luck Jeff
Posted on May 31, 2009
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Refrigerator door drags and does not shut properly.
adjust hinge remove hinge cap loosen screws lift up door and retighten screws cheers
Dec 12, 2013 | Maytag MBF2556HEW / MBF2556HEB /...
How to drop the front wheels on the refrigerator
You should be able to remove the plastic grill at the front bottom of the frig exposing the leveling screws which you can adjust without moving the frig.
Oct 13, 2013 | Liebherr CS2062 Bottom Freezer French Door...
How do you get the doors off? I still have the plastic stuck under them.
Hello Katiewachter,
I understand that you want to remove the doors from your Kenmore refrigerator. I would be glad to help you with this you will need a few tools to do this here is a list of the tools you will need.
Flat screw driver
Philips Screw driver
1/4 nut driver or socket and ratchet
5/16 nut driver or socket and ratchet
1. On the top of the fridge there are little plastic caps on the corners next to the doors of the fridge. There is a screw in the middle you will need to remove this screw in order to get to the hinge.
2. Under this cap there will be 2 or three screws and a quick connect of wires. You will want to disconnect the wire connector it should have a lock you push together and then pull apart.
3. Once wires are disconnected removed the screw hold the door as this is the top hinge.
4. Lift the door and that door is removed
5. Repeat for the other side
The Freezer Door
1. Open the door and notice the drawer that slides with it there are four screws that attach the door to the drawer
2. Loosen the screws so that the door can be lifted up and the door is removed
Reattach the doors by reversing the directions.
Thank you for choosing FixYa.com
Justin
May 11, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Water at the bottom of frig inside under crisper draws.checked door gasket it is fine cant see where water is comming from . any ideas
1. Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
2. Step 2 Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets
3. Step 3 If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls.
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Check out this link, its a video shows you how to fix a leaking fridge.
Apr 12, 2010 | Whirlpool ET1FTKXK Top Freezer...
My liftmaster garage door only opens 8 inches and then stops
It sounds like the opener is stopping because the weight of the door is tripping the lift sensor on the opener. There are two screws on the side of the opener to adjust the lift and close pressure. Find the lift pressure screw and ajust it higher to see if that remedies the problem.
Also, because you said the door will not stay open at the top when you open it manually, I think your springs are not adjusted correctly. They should hold the door open in the up position when not connected to the door opener. That may be the reason the opener lift pressure is kicking it out.
If you have to adjust the springs, be careful that you know what you are doing. There is a lot of potential for getting hurt if you don't know the proper proceedure.
Good luck.
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
I changed the door from right to left hinge, but there is a gap at the top of the door, and I cannot figure out how to adjust the door to eliminate the gap.
make sure that you used all the spacers properly
but 9 out 10 times
loosen the top hinge do not remove the screws, lift he door up inot place if your in the right screw holes on the top hinge you should have enough play to close the gap then tighten the door as you hold it in place
hope this helps
Oct 24, 2009 | Refrigerators
How to adjust the passenger door on 95 nissan pathfinder
There are hing bolts to adjust the gap in the door on the top and bottom, loosen them and move the door into position and then close and make sure the gap is even all around. If the door is not latching properly then there are two star screws in the door jam you can loosen and move the latch hook out and tighten back down to get the door to latch tighter, however if the plastic is wore off the striker plate it needs to be replaced or it will rattle no matter what you do.
Aug 14, 2009 | 1995 Nissan Pathfinder
Refridge door does not close evenly on my side by
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Jul 24, 2009 | Refrigerators
Fridge door will not stay shut
Glenn,
Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
May 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
