Question about Euro-Pro Shark 60 - 384
Cannot get thread from bobbin to feed up, Help!!
Have the Euro Pro Shark and cannot get the thread in the bobbin to catch with the top thread. Any suggestions
Cananyone help me with this. anna
Posted on Sep 14, 2009
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
Shark model 361 when drawing up the bobbin thread it wont catch upper thread wandering what the bobbin looks like for this machine
try changing the needle
rethread the machine top & bobbin
check with sewingpartsonline.com-- to see if they show a picture of the bobbins for that machine
May 27, 2012 | Euro-Pro Sewing Machines
I can't get the bottom thread to come up with the needle on my euro-pro shark intelli-sew
try this
make sure there is a 3-5 inch tail on bobbin thread
make sure there is a 3-5 inch tail on top thread, then hold the top thread tail with your fingers (away from the needle) & with your other hand turn the hand wheel manually on the right side of the sewing machine,, slowly letting down the needle down into the bobbin area & see if the bobbin thread will pick up this way
Sep 25, 2010 | Euro-Pro 9105 Computerized Sewing Machine
Machine will not advance
Check to be sure the feed dogs are engaged (up) and the bobbin winding features are disengaged.
Apr 10, 2010 | Euro-Pro Shark 80 - 7133
Upper Thread will not pick up Bobbin Thread
Make sure the needle is installed according to the manual.
Thread the machine with the presser foot up.
Refer to the manual to make sure the bobbin thread is feeding from the bobbin correctly and though the guides.
Hold on to the end of the top thread, lower and raise the needle to bring up the bobbin thread.
Take both threads under the presser foot and to the back of the machine.
Test the stitching on a scrap of fabric and if the machine is still not forming a stitch, the machine may need the timing adjusted by a service tech.
Mar 12, 2010 | Euro-Pro Shark 80 - 7133
I keep having the same problem. I have the 7133 sewing machine and the top thread keeps getting stuck on the bottom. It's not the bobbin thread that does it but the top thread which gets caught on the hook...
Sounds like insufficient tension on the top thread. THIS may be due to variation in the thread itself or incorrect adjustment.
ALSO I recently found out that some bobbins have a metal core that can catch the thread as it goes over. The person recommended using the plastic bobbins that have smooth angled sides.
Nov 20, 2009 | Euro-Pro Shark 80 - 7133
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
Zigzag stitch pulling tight, looks wrong
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
May 08, 2009 | Euro-Pro Shark 60 - 384
Machine won't sew
Change the needle and be sure the flat side is to the back. Rethread the machine. Remove and reinsert the bobbin. Hold the top thread and turn the handwheel to see it the top thread will pick up the bobbin. If yes, it should sew ; if not, it is probably out of time and needs to be seen by a technician.
sewman7
Jul 15, 2008 | Euro-Pro Shark 60 - 384
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Euro-Pro Shark 60 - 384 Logo
421 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
