Question about Milwaukee Tool Milwaukee 5192 4.5 Amp Die Grinder
Cannot figure how to get the point onto the die grinder.
Milwaukee 2"die grinder 4.5 amps 5192 How do you put the point into the collet?
  • Samuel Charles Spriggs May 11, 2010
    I need more info, please:
    - Do you have the collet wrench which comes with the unit?
    - What size bit are you trying to put into the collet?
    - Does the shaft-lock mechanism work?
    - Do you have both the 1/8" and the 1/4" collets?
  • 268 Answers
Here is a link with illustrations on installing grinder points. Scroll about 1/4 of the way down and you'll see two links for "Operators Manual" Click the one that matches your model.
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/All.aspx?ProductId=5192
Hope this helps you out.
Posted on Sep 18, 2009
Need switch for milwaukee model no 6066 serial no 0075355593 sander/grinder.please help THANK YOU.
Part # 50
http://www.ereplacementparts.com/milwaukee-6066-ser-753a-sander-parts-c-131_4779_5141.html
Aug 12, 2013 | Milwaukee Tool Milwaukee 6066 - 6 7''/9''...
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
Want to put in new 1/4" collet cone.......how
Undo the collet nut then find something that you can get a firm grip on the old collet and pull it out. If this doesn't work and it is still stuck carefully try an eze- out to remove the old collet. Once you have removed the old collet just insert the new one and replace the nut.
Feb 11, 2011 | Makita GD0600 1/4 Inch Die Grinder With...
I cannot get off the abrasive cutoff wheel I put on the grinder
I believe the thread is left hand, but close inspection should verify. Also you should never over tighten cutoff wheels or grinding wheels. You should be able to remove with a gloved hand while holding button on top with the other hand
Dec 26, 2009 | Milwaukee Tool Milwaukee 6" Right Angle...
How do I remove a broken off collet? On my Milwalkee Die Grinder the collet is Broken off in the Shaft. I need to remove the collet to install a new one.
I would try and put the collet nut back on and gently hit the side with a hammer to see if you can loosen it, this should work
Dec 16, 2009 | Milwaukee Grinders
The worm gear broke
Time to buy a new air grinder!!
Aug 27, 2009 | Viking Die Grinders: 1/4" Mini Die...
I can't find a 1'4" collet for a Milwaukee DG14-50-Q die grinder. The removable collet chuck came with 6mm & 8mm collets. The collet Id No is 48-66 0965 but is no longer made. Does anyone know of an...
The 48-66-0970 has ribs on the outside and fits the old 5195 die grinder. If this is accurate let me know and I will try further to locate it for you. Where are you located as this might help
May 15, 2009 | Milwaukee Tool 48 66 0975 Collet 1/4" Die...
Need brushes and on-off switches for milwaukee 6140-6 hand grinders is this grinder obsolete?
I would need the exact model number and serial number to help but the brush number is 22-18-0710 and there could be a couple different switches. Either give the ser number (the alpha code) or you can go direct to Milwaukeeelectrictool.com and type in the model number 6140 on the page for the breakdown. it might be easier to let me do it. I worked there for 17 years and if you can't get the alpha code look at the switch and I would need a good description of it
Feb 20, 2009 | Milwaukee Tool Factory-Reconditioned...
Milwaukee Tool Milwaukee 5192 4.5 Amp Die Grinder Logo
443 people viewed this question
Top Milwaukee Tool Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Vernon Taylor
Are you a Milwaukee Tool Grinder Expert? Answer questions, earn points and help others
